Is it broken? Manual focus
Discussion in 'Panasonic Chat' started by Catriona, Nov 17, 2018.
  1. Catriona
    Catriona Well-Known Member
    I have an LX100 which up till now worked fine.
    I normally operate on aperture priority.
    I moved the slider to Manual focus and I have suddenly found that auto focus still persists. This has never happened in the past.
    What should I check? I've looked in the menu but I'm not having any luck solving this.
  2. RogerMac
    I am not familiar with Pany but assume it has the MF slider on the lens if so it would be worth cleaning the lens contacts
  3. IvorETower
    IvorETower Little Buttercup
    If the lever/switch has not been moved for a long time, it may just be dust or whatever on its contacts. I suggest operating the slider a few dozen times with the camera off, then see if that has fixed the issue. I'd be very wary of spraying some electrical switch contact cleaner into the insides of a camera .....
    Catriona likes this.
