Home weather stations
Discussion in 'The Lounge' started by Malcolm_Stewart, Aug 24, 2017.
  1. Malcolm_Stewart
    Do any of you have a "weather station" ? - i.e. an indoor base station and an outdoor sensor so that from the comfort of your home you can tell how cold it was outside during the night etc. (and these days, many more aspects of local weather)
    I've had an early Oregon base station with 3 channels and using 433 MHz for very many* years, with two external temperature sensors. One of the remote sensors has now failed, so I'm looking for a replacement. My gear is so old that it's not listed in the compatibility lists of what's now on offer.
    * The once tough plastic sunshade I devised has been turned by the sun's UV to a very fragile reminder of what it once was!
    Checking out the usual sources, it seems as though complexity has increased, but reliability still seems somewhat suspect, so I'm hoping that some here may have some pointers for me based on 5 years plus usage.
    Have any of you used a Stevenson screen? Connected to your PC so that graphs can be drawn?
    Many thanks
  2. Catriona
    Catriona Well-Known Member
    I had an MsF system which gives the basic info on temperature, hunmidity etc and it has an external sensor too.
    However, I could never find the data I needed to set the local pressure setting. Not on the accompanying booklet, nor the website.
    It also had a nasty habit, when changing the batteries, of resettting alarms and waking me up at 2.30am and 5.30am. I once found the way of switching it off, but the last time, I just couldn't find the off setting for alarm, so I removed all batteries from both pieces of equipment!
    Strangely, I still wake up around 2.30 and 5am!
    Not much help to you, unless you are considering this model - but I wouldn't recommend it.
    I now have a very simple, no alarm, pair of sensors by Sainlogic, which just give external and internal teperature readings.
    I bought an analogue barometer which is great and tells me pressure, humidity and temperature too (accurately)!
    My favourite guide, however, is the Weather File from my local port authority. https://weatherfile.com/?loc_id=GBR00019 which, so long as I have an internet connection, gives me accurate local info.
    Kate
  3. Malcolm_Stewart
    Thanks Kate,
    That's a new one, with the nearest location for me at Luton Airport, about 25 miles away. It also lists some professionally priced gear - way out of my range for this interest.
  4. steveandthedogs
    I've got one of these: https://www.maplin.co.uk/p/black-usb-wireless-touchscreen-weather-centre-n96gy
    It's about twelve or more years old. Probably a fair bit more.
    Unfortunately, the internal software seems to have joined the Awkward Squad - it works, but will not write to its memory. I've just checked with Maplin and they have more than doubled in price since I got mine. So no new one for a while.
    When they work, they are very good, download to a computer, easy to read, but setting up after a battery change is a pain in the backside - takes ages to go through everything.
    S
  5. Malcolm_Stewart
    Hi Steve,
    Thanks for your info.
    I was considering that model, but the user interface on my partner's rain gauge also leaves a lot to be desired. One of the problems perhaps is that the interface designers are probably in their late teens or early 20s, and have no time to use one of these, so don't understand how simply awful the interface can be.
  6. steveandthedogs
    Give me buttons and dials any day!
    S
    Catriona likes this.
  7. RovingMike
    I've got a pine cone.
  8. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    (Linked from Google)
  9. PhotoEcosse
    PhotoEcosse Well-Known Member
    I rely upon Carol Kirkwood, despite her speech impediments.
  10. PeteRob
    We've got a weather station. I reckon it must be more than 10 years old because one of my sons set it up. Earlier this year I cut it out of the hedge that had grown around it. Logically it must use batteries in order to transmit to the receiver but I'm blowed if I can see where they are.
  11. Malcolm_Stewart
    I've now done other searches, but yesterday I decided that I'd go for a Maplin "Professional Wireless Weather Centre - N25FR" - at least that was on the cardboard case. The instructions (which ought to be used as a test text at the opticians) don't mention "Professional", and that's in line with the very small screws etc. for fitting the components to the mast. Assembly was fiddly, but essentially straightforward - the data cables from the wind-speed and rain gauge are far too long, but use PO style connectors for which I don't have the correct crimp tool - they'll stay long.
    Initially I was concerned that the two temperature sensors were in dispute about local temperature, but after being close together overnight, they agreed to within 0.1 degC, and agreed with other thermometers . The unit measures barometric pressure, so I can now check my 70 year old aneroid barometer.
    I've now got a pole in the garden, and all I need now is some daylight so that I can see to put the assembly on top of the pole. Thanks for all your help.
  12. Malcolm_Stewart
    Two months have passed, so here's an update -
    I set up the weather station on a guyed ~2m pole in my back garden, and it's told me the temperature, rainfall, humidity and wind speed for the last two months. It's also told me the barometric pressure, and the trend. It's surprised me that frequently the anemometer is rotating when the leaves on nearby bushes aren't showing any movement - and vice versa. The lowest temperature so far was last night / this morning when it dipped a little below 0degC.
    This update was prompted by me realising that my old, "failed" Oregon remote unit was now working properly again, and had synchronised itself to the Oregon base station's channels - something I was unable to achieve last August, but which has happened by leaving the two devices close together. (The new Maplin weather station's instructions suggest that re-syncing channels can be done by button pressing, or by leaving close together.)
  13. Catriona
    But are you any warmer? ;)
    Only kidding you..
    Hope you didn't have the alarm problems I did with the indoor unit!!
  14. Footloose
    Footloose Well-Known Member
    That's not a nice way to treat a Pole!
  15. Catriona
    Mind you, the ones I know are built pretty solidly! Ha!
  16. Andrew Flannigan
    For umpteen years there was a sign on one of the roads into Exeter that read "Rustic Poles Cut To Size".
  17. John Farrell
    I suppose you paid by cheque.
    peterba likes this.
  18. Andrew Flannigan
    Only once they've Finnish-ed the job.
    peterba and John Farrell like this.
