focus error
Discussion in 'Fujifilm Cameras' started by tonycro, Apr 10, 2015.
  1. tonycro
    tonycro Well-Known Member
    my friend has a fuji bridge camera - I know make and model would be useful at this point, but should be posted a little later - and has a focus error. The lens doesn't come off so no obvious way of a DIY fix.
    Anyone know of a Fuji repair house ?
    tony
    Most camera shops have repair contacts. Google says https://camerarepair.fujifilm.co.uk
  3. spinno
    This will probably sound a daft question but it's not in macro mode whilst trying to take a photo at distance is it? Mrs S's daughter once had this problem:eek: until I eventually figured it out.
    Another issue is grit getting in the lens as it collapses/opens...yes you've guessed it
  4. tonycro
    thanks chaps, just checked and won't let us change between macro and 'normal'off to follow the Google linkta
  5. PeteRob
    Look to see if there is a "reboot" option as these things are computers and sometimes things get "stuck".
    Odd settings can catch you out. On my Canon SLR you can remap the function of the shutter button so it does not activate focus (handy if you want to fix the focus position) but if you forget that you did it then the symptom is a "broken lens" that won't focus.
    The one thing that I don't get on with with compacts/bridge cameras is context sensitive menus. The thing you want to change depends on some combination of buttons being pressed before it shows in the menu.
  6. RovingMike
    If it really is bust, you can send it to Fuji, but get a mortgage first. They tried to charge me more than my old x10 cost to fix the focus.
