FAQ: Safe trigger voltages for EOS SLRs
Discussion in 'Canon Conflab' started by Benchista, May 5, 2009.
  1. Benchista
    Info here courtesy of Chuck Westfall.
    It seems that ALL Canon DSLRs are safe up to 250 volts, EXCEPT the D30, D60, 10D and 300D, which are only safe up to 6 volts. The film EOSs are safe up to 6 volts, EXCEPT the 1, 1N, 1V and 3, which are all safe up to 250 volts.
  2. Larry Shone
    Larry Shone Well-Known Member
    Good stuff Nick! I also found voltage tests for various flashguns on another site and the flash I have, a Cobra 440AF, has a voltage of 3.6V. But altho its safe on the 10D I've been informed on here that it doesnt work on that camera, and I've not tried.
  3. moooocow
    moooocow Member
    Hi all . I wanted to use a very old Prinz flasgun on my 5D . Being worried about the voltage I bought a cheap trigger unit . Cost me about £20,is well made and works fine and also gives me the opertunity to place the flash off camera . Rex . P.S. It's branded 'ishoot'
  4. Ben Myerson
    Ben Myerson Member
  5. eagerbeaver
    eagerbeaver Well-Known Member
    Be careful. There is a difference between the PC socket and the hotshoe. Read the manual.
  6. neilt3
    neilt3 Well-Known Member
