Elements Question
Discussion in 'Computer Related Help & Discussion' started by fabs, May 31, 2007.
  1. fabs
    fabs Well-Known Member
    I have Elements 5 and when I click on "File" I get the option "Save for Web", a very useful tool I've found, especially for preparing images to post on this forum.
    However, a friend of mine also has Elements 5, but instead of "Save for Web" his says "Save a copy" which does exactly the same as "Save As".
    I told him to try Alt+Ctrl+Shift+S but that does the same as "Save As"
    Has anyone come across this before and is there someting in the settings he can change to rectify this?
    Thanks :D
  2. Fen
    Fen Well-Known Member
    Alt+Ctrl+Shift+S is standard in Elements and Photoshop for "Save for Web"
    Gawd knows why it isn't working on his though.
  3. El_Sid
    Might be worth his while going into 'Edit>Preferences' and trawling carefully through them to see if anything is set this way.
    Only hassle I have with 'Save for Web' is that frequently it just won't start up at all (PS7) which means I have to start up my ancient copy of Elements2 and do it from there....... :( If anyone has any ideas why PS7 does this I'd be interested to hear...
  4. Lounge Lizard
    Maybe the image he had loaded at the time wasn't in a Web-compatible colour space. Just a thought. Do the comparison with the same image loaded.
  5. fabs
    I've had a look but couldn't see anything.
    Not to worry, he was getting on ok without it so.... :D
