Elements 9 won't save image as a jpeg...
Discussion in 'Computer Related Help & Discussion' started by gray1720, Oct 10, 2017.
  1. gray1720
    gray1720 Well-Known Member
    ...so what am I doing wrong this time? I expect it's me, as usual...
    I'm editing a photo I scanned from a print and saved as a TIFF. Now I want it as a JPEG for faster downloading to a photobok site, but for some reason Elephants is only giving me a limited number of file type options - PSD, Targa, Photoshop RAW, PNG and TIFF I think.
    Bright ideas welcomed!
    Thanks,
    Adrian
  2. AlanW
    AlanW Well-Known Member
    Does the image have layers? If so, you'll have to flatten/merge them before you can save it as a jpeg. Hope that does the trick!
    Alan
    EightBitTony likes this.
  3. gray1720
    I'll check this evening - I didn't think I'd added any layers, but...
    Adrian
  4. AlanW
    Also, if the tiff image is 16 bit you'll need to convert it to 8 bit to save as a jpeg ....I think that's right, I'm on a bus right now!
    Alan.
  5. IvorCamera
    IvorCamera Well-Known Member
    Make sure you press.....save as.....and not......save......You probably know this but I just thought I would mention it.
  6. gray1720
    Ta -it was the 8-bit thing in the end. Much appreciated!
    Adrian
    AlanW likes this.
  7. Snorri
    Snorri Well-Known Member
    That WPS my guess, if you are working with higher than 8 bit It won't do .jpg. Good to see that problem is solved.
