Do you still use a Fax machine?
Discussion in 'The Lounge' started by Footloose, Jul 12, 2018.
  1. Footloose
    Footloose Well-Known Member
    Well, looks like the NHS are still using at least 9000 of them and probably masses of machines still using Win95. Now the latter issue may well be that a fair bit of the medical kit can't/ hasn't had software updates for the later O/S's, but that (in my opinion) raises the issue why MS, can't produce an O/S that's capable offering users the ability of still using 'out of date' drivers and software.
    https://www.independent.co.uk/news/...-newcastle-surrey-sussex-health-a8443006.html
    Is this because MS gets it's newest programmers are too 'Geeky' and just don't want to integrate what the previous O/S used, because they think what they come up with is 'better'? After all, I can use pretty-well any keyboard with any O/S, so why can't the same thing apply to the Inputs & Outputs of other devices? I've never heard a valid reason why these can't be put through some form of 'converter' which then feeds that into the 'new' ones. Laziness? the urge to flog newer hardware? I've got a Dye-Sub printer which is incapable of running because my PC uses a newer O/S and it's manufacturer, is still only providing drivers for older than Win 10 machines, on the machines they are currently selling / manufacturing!
  2. SXH
    SXH Well-Known Member
    Not personally, but the Observer Everyman Crossword entries can be sent by post or fax.
  3. RobertCoombes
    I have always assumed that they stuck to Fax because it is virus free. As to old drivers, I used an old unsigned driver for my Nikon scanner. It involves using different setting for one session, a web search will tell you how.
  4. SXH
    True, but when I was still working ( grief, is it 10 years ago?) we used to get a lot of Fax spam - used to clog up our big printers on a regular basis (the phone system re-routed it there automatically).
  5. PeteRob
    I've got a fax built into my all-in-one printer. I don't have a phone line run into the office (I use Skype telephony ) but I could hook it up if I wanted. I think most company systems using linked telephony/computers will now accept a direct fax to the desktop in the same way as scan-to-pdf and e-mail. Independent fax machines have gone as the fax/copy/print function has become integrated. There is still a need to send facsimile documents. If I send an invoice I print it, sign it, scan it and email the pdf, then wander down the post office and put the original wet-inked version in the mail. Then I print the scan for the paper file the accountant likes to see.
    It's a bit pointless bringing up the Microsoft doesn't support xxxx anymore, especially when the onus is on the peripheral maker to provide a driver. It is a fact of life. Old machines can still be used (until they break). The threat is that if they are connected to a network they are vulnerable to attack.
  6. RogerMac
    Just got rid of mine, for some years I had only one use for it - ordering repeat prescriptions of rat poison from my doctor. However it needed a new toner and I am moving house so it did not seem worth moving a rather bulky machine. I think that most doctors accept repeat requests via email now so I will investigate that when I get a new doctor. It had stopped having a dedicated line years ago and only got plugged in when I needed it
  7. Footloose
    Probably mentioned this before -
    I knew someone who used to live in S.A and when his pharmacy ran out, he'd go down to the hardware store and get some Warfarin there ... Presumably, Rats don't 'deserve' the meds version, or haven't complained. ... o_O - Which raises the stupid question, has anyone (eg animal Rights campaigner) complained the pest version, is inhumane, as it might have some additional nasty side-effect - on the Rats? :eek::)
  8. spinno
    Does it take pictures like my smartphone:rolleyes:
  9. Roger_Provins
    A few years ago when I was still in gainful employment we could only receive examination results via fax or recorded post. I don't know if it's still the case.
  10. Petrochemist
    The photocopiers at work can fax things too. It's still a convenient way of sending contracts etc.
    WRT the older drivers, we were occasionally using some windows 3 software on win 98 till about a year ago.
    The last instrument for that has now failed, so the newer hardware has to be used, it's just not as easy to automate.
    It's not the only place where older software has proved much more user friendly. Modern laboratory software is generally written to be compliant with Pharmaceutical regulations which have no bearing on us & require any changes to be documented to the roof...
  11. Bazarchie
    Bazarchie Well-Known Member
    Probably not seen a fax for 15 years.
  12. Benchista
    Haven't seen or sent a fax in years.
    But I do have a working Win 3.11 machine.
  13. AndyTake2
    AndyTake2 Well-Known Member
    The jump from Windows 3.1 to 95 killed a hell of a lot of machinery. 98 to XP did a similar thing. I can remember having to dispose of a scanner, but there were lots of other bits and bobs that stopped working. Never had a fax machine, apart from one built into printers.
  14. Trannifan
    Trannifan Well-Known Member
    Then again, given the apparent experience of the NHS with IT providers and projects over the years................"If it ain't broke don't fix it!"
    Lynn
  15. Benchista
    Our surgery has online ordering of repeat prescriptions. Many pharmacies will do it for you, too.
  16. Malcolm_Stewart
    Back when (~1995?), I "saved" a microfiche reader, and a motorised microfilm reader from the skip - thinking that they'd come in useful one day for my family history searches..I've never bought any fiche or films, they've gathered masses of dust, and I'm now offering them foc to an agency which specialises in moving analog data to digital.
    I remember having fax software many years ago, but certainly not now, and again the onward "progress" has stopped me being able to edit video as easily as I used to be able to do.
  17. PeteRob
    We have a microfiche reader for that very purpose!
  18. Roger Hicks
    Still have one; use it for communicating with doctors occasionally. No dedicated line any more though: I use it for sending only, and have to plug it in.
  19. Roger_Provins
    Our local pharmacy gets my prescription from the docs every 28 days and delivers it to me. How lazy can you get! ;) It's not a branch of large chain but just a small independent owned and run by a young couple of pharmacists.
  20. SXH
    Whereas every twelve weeks, I have to take two walks to my local pharmacy - first to order the repeat and a week later to collect it. Well, I have to get SOME exercise! ;)
