Discussion in 'Appraisal Gallery' started by jsterry1, Mar 23, 2012.
  1. jsterry1
    jsterry1 Member
    Playing with SWMBO's mother's day flowers.
    Does this work?
    It is black and white with the yellow 'colour popped', which I need more practice with. It may not be everyones cuppa but I like it.
  2. BrianWall
    BrianWall Well-Known Member
    Yes, I like it except the dark areas are so dark there is only a hint of detail. A touch of fill would help put the flower in context maybe?
  3. jsterry1
    jsterry1 Member
    Thanks for the advice. Not being a whiz with Photoshop how would i go about adding a touch of fill to the dark areas? I like the stem being almost invisible but would like it to show up enough to give more depth to picture.
  4. BrianWall
    You can lift the shadows in a number of ways, depending upon which application you're using. Look for a Levels, a Brightness or even a Shadows slider. This will lift the darkest parts but leave the rest alone. Adjusting an exposure setting won't retain the flower correctly.
