Dad bag for small system camera
Discussion in 'The Lounge' started by Learning, Sep 22, 2017.
  1. Learning
  2. Zou
    Usual journalistic standards I see - "they're not called... fanny packs any more" followed by two tweets referencing them as just that. Ho hum.
    Anyway, I personally haven't used one for a while but used to find it hugely practical. Not tempted by the belly one though. :)
    That's gross.
  4. Footloose
    Footloose Well-Known Member
    It says it was created - or should that be aborted?) by the British designer Albert Pukies - Oh, the irony!
    Done_rundleCams likes this.
  5. spinno
    I have two and I also have a shoulder man-bag. Necessity because of all I need to carry with me.
  6. Done_rundleCams
    I have a boring belt /bum bag/fanny pack from Lowe Pro and used it when I was using my Hexar AF back in 97-2000 era ;)
    Jack
  7. Footloose
    I also use a bum-bag and have added to the rear an extra section of webbing - secured at 3 points with white sail whipcord thread - behind the bag, (as you can see in the photo below) so that when the belt is done up firmly around my waist, the bag's volume is not also restricted/compromised. With this additional section, the usable capacity of this bag is increased by at least 35% and it's a lot easier to get anything in and out of it unless in it's original 'form' you do up the belt strap is a lot looser.
