Competition - APOY 2015
Discussion in 'Amateur Photographer Of the Year (APOY)' started by Chrissie_Lay, Mar 3, 2015.
  1. Chrissie_Lay
    Chrissie_Lay AP Editor's PA
  2. TH-Photos
    TH-Photos Well-Known Member
  3. AlexDenny
    AlexDenny Well-Known Member
  4. I've amended the link and thanks for pointing this out.
    Chrissie
  5. ludofarine
    ludofarine New Member
    Hi :)
    I've got a question regarding the image size that we send for APOY.
    "Your image must be at least 2,700 (3,000 maximum) pixels along its longest dimension" it says.
    My Photos are usually 4608*3456. Does it mean I should reduce it? If so, which size is the most appropriate?
  6. Catriona
    Catriona Well-Known Member
    Which part of the above instruction don't you understand?
    If you use any software, there should be a means to reduce the image size. It's up to you how small you want to make it, but as is said, it has to be at least 2700 pixels on the longest side and up to 3000 pixels if you wish - but no bigger.
  7. hazzatori
    hazzatori Well-Known Member
    Yes you should reduce...
    I understand there are a lot of rules and it can be difficult to grasp everything,
    But its up to you what size to reduce too as long as its between 2700 - 3000px along the longest side, I have personally made the longest side 3000px if you lock the Ratio then it will adjust the shortest side too..
    it seems unless you are a reg on these forums, then the only support you get is sarcastic support.
    Good Luck. :)
  8. Trannifan
    Trannifan Well-Known Member
    Is it compulsory to accept a prize? Having read the rules, I'd appreciate clarity on this point. Quite simply, what is on offer is totally incompatible with my equipment and therefore of no use whatsoever to me, so that, should I enter and, wonder of wonders, actually win, I would have to say that I don't want it, winning the round is prize enough. ( Prizes never particularly motivate me anyway). Am I therefore excluded from entering?
    Lynn
  9. Catriona
    Haha!
    Definitely not!
    Accept and donate or sell it. :)
    Kate
  10. Phobug
    Phobug Well-Known Member
    Is there a sticky with all rounds / subjects for the full year?
  11. Catriona
    There is in another place, however, does this help?
    [h=2]Plan your APOY 2015 year[/h]Below is a list of this year’s rounds, a synopsis of what we’re looking for and the dates they will be announced. When you are planning your entry, remember to take into consideration the criteria of fulfilling the brief, creativity and technical excellence on which you will be judged.
    [TABLE="width: 100%"]
    [TR]
    [TD] Theme[/TD]
    [TD] Synopsis[/TD]
    [TD]Announced [/TD]
    [TD] Closes
    midnight
    [/TD]
    [TD] Results [/TD]
    [/TR]
    [TR]
    [TD] 1. Night Life[/TD]
    [TD] Low Light Photography[/TD]
    [TD] 7 Mar[/TD]
    [TD] 29 Mar
    closed[/TD]
    [TD] 25 Apr[/TD]
    [/TR]
    [TR]
    [TD] 2. Going Abstract[/TD]
    [TD] Abstract images[/TD]
    [TD] 4 Apr[/TD]
    [TD] 26 Apr
    closed[/TD]
    [TD] 30 May[/TD]
    [/TR]
    [TR]
    [TD] 3. The Wider Perspective[/TD]
    [TD] Creative Wide Angle[/TD]
    [TD] 2 May[/TD]
    [TD] 31 May[/TD]
    [TD] 27 June[/TD]
    [/TR]
    [TR]
    [TD] 4. In Focus[/TD]
    [TD] Shallow depth of Field[/TD]
    [TD] 6 June[/TD]
    [TD] 28 June[/TD]
    [TD] 25 July[/TD]
    [/TR]
    [TR]
    [TD] 5. Up Close[/TD]
    [TD] Macro (insects/flowers/plants)[/TD]
    [TD] 4 Jul[/TD]
    [TD] 26 Jul[/TD]
    [TD] 29 Aug[/TD]
    [/TR]
    [TR]
    [TD] 6. On the Street[/TD]
    [TD] Street Photography[/TD]
    [TD] 1 Aug[/TD]
    [TD] 30 Aug[/TD]
    [TD] 26 Sept[/TD]
    [/TR]
    [TR]
    [TD] 7. Lay of the Land[/TD]
    [TD] Landscape and cityscapes[/TD]
    [TD] 5 Sept[/TD]
    [TD] 27 Sept[/TD]
    [TD] 24 Oct[/TD]
    [/TR]
    [TR]
    [TD] 8. Shades of Grey[/TD]
    [TD] Black & White[/TD]
    [TD] 3 Oct[/TD]
    [TD] 1 Nov[/TD]
    [TD] 28 Nov[/TD]
    [/TR]
    [/TABLE]
    Read more at http://www.amateurphotographer.co.u...er-of-the-year-2015-42803#rr0KmlPMHbYcTuuy.99
  12. PMurrell
    PMurrell Well-Known Member
    Is a current top 50 overall standings list available?
  13. PeterHaken
    PeterHaken Member
    When will next No 9 start? Can i join the next round, do you have to sign up anywhere or can we just submit in the next round?
    Cheers Pete
  14. Catriona
    Probably February or March next year, going on current indications.
  15. mark_jacobs
    mark_jacobs Retired
    APOY 2015 consisted of 8 rounds. APOY 2016 will be announced next year in the magazine and online, there is no need to 'sign up'. Also you can enter as many rounds as you wish to, one entry per round.
    Regards
    m
  16. PeterHaken
    PeterHaken Member
    Ah ok cheers, will keep an eye out now i have been inspired again.
