Canon G series cameras problems
Discussion in 'Canon Conflab' started by wheeliebug, Apr 22, 2012.
  1. wheeliebug
    wheeliebug Member
    Has anyone had problems with their Canon G series cameras?
    So many new cameras of various brands are being brought out with design faults coming to light after they are released.
    I am interested in getting the Canon G1X, but I have a G11 and the control dial on the back around the 4 way switch has stopped doing what it should. It either jumps, misses a menu item or doesn't do anything and it will cost £100 to get it fixed. Considering the cost and age of the camera, it is not worth it.
    What problems have you had with your Canon G series cameras.
    I had a G6 and that stopped working. But that might be due to being dropped on concrete.
  2. mark_jacobs
    mark_jacobs Retired
    Hi wheeliebug :) using the search facility, the only reference I can find to such an issue on this forum is your post from earlier this year. FWIW my G9 dial is still tip-top.
  3. Old git
    Old git In the Stop Bath
    Well if you don't want the G11 ;););)
  4. RogerMac
    My G2 is still working well. I am a bit worried about the battery and the articulated screen is a bit lose - if I used it more I would attempt to sort both those out. Being rather older than yours I am not sure how much value this adds to knowledge of the longevity of the current models. The IBM disc drive that came with it died a long while ago.
    Edit: I have just been and taken a photo with it and it appears to be in GWO, apart possibly from the battery.
  5. nimbus
    I would reckon that it is worth spending £100 to repair a G11.
  6. wheeliebug
    wheeliebug Member
    Although the control dial on my G11 is not working as it should, everything else on it works just fine. There is a way round most things that the control dial does so I still use it regularly with a few restrictions.
    That is why I said it isn't worth spending £100 on on the repair.
  7. cartman
    cartman Member
    My G6's control dial hasn't worked properly from about 6 months after I first got it from new. However it's getting worse with some very odd behaviour unless Tv mode is selected.
    I got a £60 quote from Lehmanns a year or two ago but haven't acted upon it and now I'm not sure it's worth it.
  8. Benchmark
    Benchmark Well-Known Member
    So far I have had a G3, G5, G7, G9 and currently a G11.
    All have been used extensively in my day job (marine survey work), and they get knocked around a bit, but all have worked flawlessly for me.
    There was an odd issue with the screen on my G5, where the top few lines were always black, but nothing else.
    The G9 was noisy, and so was replaced with the G11 almost as soon as it came out. The G11 is by far the best as far as I am concerned, although I do miss being able to plug the charger into the camera! Having biggish fingers I also find it far too easy to push buttons by mistake.
    I have never tried a G12, although from what I have heard there is very little difference to the G11.
    I saw the new G1X in an airport duty free shop earlier this week. I liked the look and feel of it, (and that there was somewhere to put my thumb). I also like the promise of low noise at high ISO settings, but it seemed quite pricey at about £650, so I will probably wait a while.
    Other than a Canon fax machine that was a bit 'iffy' I have never bought a dud Canon product yet.
  9. velocette
    velocette Well-Known Member
    I've used a G9 extensively with no problems until it got smashed when I changed to a G12 which has taken hundreds, maybe thousands of photos over the last year with no problems. I always carry the G12 in my backpack so there's seldom a day that goes past without it being used. Once the G1X comes down in price as it will it'll be on the list to replace the 12.
  10. Benchmark
    The G1 X will have a much shallower depth of field than the G11 / G12, which might actually make it easier to use manual focus. It is slightly bigger and heavier than the G11, but not that much.
  11. Zak52
    Zak52 Well-Known Member
    G10 for over 3 years now......no problems whatsoever, amazing battery life. I love it and would recommend the G series to anyone wanting a good compact as either their main camera or to supplement their DSLR.
  12. Guitarist
    Guitarist Well-Known Member
    My G11 so far has been faultless, but I would spend £100 to mend it if necessary. What's the alternative? Any comparable replacement is going to cost a hell of a lot more than that!
  13. Guitarist
    Yep, agree fully with that.
  14. iroberts
    iroberts New Member
    My G11 became unresponsive ( zoom stopped, buttons on back nolonger had any effect ) in March, after only 1 year of use repair cost £175 for new 'flex connector' + recalibration .
    Camera was kept in case and not dropped or roughly treated ! so yep costly & fragile
