Canon 100-400L IS
Discussion in 'Lens Matters' started by Wavemachine, Feb 3, 2018.
  1. Wavemachine
    Wavemachine Member
    a few months ago I bought a second hand Canon 100-400L IS, this is the original mki version.
    I noticed today when taking the lens off there is a slight chinking noise when it is turned over, I am guessing this is the bearings in the friction ring, is this normal?
    The early IS lenses can rattle a bit. I don't know about that particular one.
  3. Wavemachine
    Wavemachine Member
    I am guessing it is a fairly early version of IS as it is only two stop and the lens was originally released in 1998.
  4. nimbus
    The IS works by slight movement of some elements, as such they tend to have a slight rattle, only worry about it if things are not working properly.
  5. Wavemachine
    Wavemachine Member
    Cheers thanks, I am looking at the mkii version of the lens and was looking to sell this one maybe it has always done it and I haven’t taken any notice of it.
  6. Wavemachine
    Wavemachine Member
    Thanks for the replies, the mystery is now solved, it is the Tripod ring the sound is coming from inside there, I think something has come loose as now having removed it the thumb screw won’t tighten, the thread looks pretty bad as well so I would say it was always a bit dodgy as this is the first time I have ever removed it.
    Seems to be around £120 for a genuine canon replacement but I only bought the lens in August and it has a 12 month warranty so I will try to get them to replace it.
    Thanks to everyone who replied.
