Black Beauty 4: Pentax SV
Discussion in 'Pentax Chat' started by Roger Hicks, Sep 30, 2016.
  1. Roger Hicks
  2. Done_rundleCams
  3. Monobod
    Monobod Phantom of the forum
    See my Avatar, a Pentax SV in Chrome. It is immaculate and was my father's camera. It has the M42 55mm F/1.8 lens. I have not put a film through it though, so cannot say if the shutter speeds are correct, but it sounds superb when the shutter fires. It will stay with me for as long as I draw breath and I hope my Grandson(s) will treasure it also as an engineering masterpiece. I also have the 'orange peel' black leather ever ready case.
  4. Benchista
    My SV worked well enough last time I used it, maybe 5 years ago. Only ever had one Spottie pack up on me, and that was one I got for less than a fiver - I've something like 7 S series and Spotmatics. None of them black, though. My K2 DMD is black, and nicely worn. Much prefer a little brassing on these sorts of cameras.
  5. Monobod
    Probably, if anything, it may be wise to have it lubricated. Perhaps the mirror may stop working properly? I'm not sure but perhaps a call to Pentax might be worth it.
  6. PeteE
    PeteE Well-Known Member
    I had a go and 'Lubricated' MY Silver SV I took off the base=plate carefully using a small screwdriver so as not to damage the heads (I now have a genuine JIS set from Japan)and had a look and put one drop of three-in-one oil into a developing dish and picked up a small drop on the end of some electrical fuse-wire and touched it into the gears , cogs and levers and it went in by capillary action and it has wound on 'sweetly' ever since BUT you must be very careful not to drop oil in from the actual oil container as the 'drop size' is FAR too BIG.
    [​IMG]Pentax SV by Peter Elgar, on Flickr
  7. Done_rundleCams
    Souns like it was beautifully and lovingly done, Pete :)
    Jack
  8. Monobod
    I would like to do this with my SV as the mirror stuck once and I could not remove the screw lens. Fortunately, it freed itself and now works again, but I'm sure a 'lub' is the answer. Just need to be brave.
    Done_rundleCams likes this.
  9. Done_rundleCams
    I think I might have to do that with my Ashaiflex IIb, as well or, in all probability,
    get a repair shop to do it, cuz I suck at any kind of DIY stuff :(
    Jack
  10. John King
    John King Well-Known Member
    I have been a Nikon user since errrr........ a long time ago, but these Pentax models were so well made, reliable and not very heavy. True classics.
  11. William Parker
    William Parker Well-Known Member
    Back in the seventies Pentax ran an advertising campaign that consisted of showing Pentax cameras owned by well known photographers. If my memory serves me correctly ( a risky comment these days) David Bailey's which I think was a black ES was depicted with most of it's black paint scratched off revealing the brass work.
  12. Andrew Flannigan
    I think the original Spotmatic takes the prize for prettiest SLR but its older brother runs it a very close second.
  13. Mark101
    Mark101 Well-Known Member
    My first real camera was the Spotmatic F, which I sold to a friend who still has it in her home. Biggest photographic mitake that I've ever made and I still dream of those classic lines and ease of use.
  14. nimbus
    I would say the Pentax SL, no switch to spoil the lines. I still keep one of these, it suffers from shutter taper so I don't actually use it, nut I do like looking at it!
  15. Done_rundleCams
    To me, you can't beat the K1000 (my first) or, probably, my favourite, the MX, albeit a tad dodgy (feeling)
    with bigger lenses such as. 200/2.5 or 300/4, but, of course, a winder helps the ergonomics ;)
    Jack
  16. Mark101
    Still sought after although the Chinese assembled ones aren't to my liking. If only they were still in production since I know many a college would go for them.
  17. nimbus
    It's the plastic used where there was previously metal, it really degrades the product.
  18. Done_rundleCams
    I, totally, agree Mark and Nimbus :).
    Jack
  19. Barry Reid
    Barry Reid Member
    The MX is undoubtedly the most perfect of Pentaxes. I have a very nice black one with a 50/1.4, but I must say that other, more advanced, film cameras see more use as I'm lazy and like the automation!
  20. Andrew Flannigan
    I doubt it. :cool:
    Roger Hicks likes this.
