Bit deflated with the Leica Vario-Elmarit
Discussion in 'Olympus Chat' started by RovingMike, Jul 2, 2019.
  1. RovingMike
    Having got a bit frustrated with the m43 PRO 12-40 f2.8 because of its lack of a longer end and remembering the old Zuiko 12-60, I took the plunge and ordered up the Panasonic Leica 12-60 f2.8-4 for a stiff wedge. First test vs the 12-40 seems to show the Leica OK, but not up to the Oly. Visibly less sharp at 100% on f8, both in the centre and edges.
    Must say I'm surprised because I'm used to even "toys" like the 14-40 pancake matching the 12-40 PRO. Anybody else tried it?
  2. nimbus
    Perhaps you have received a below par copy? I would expect the resolution to peak before f8 as well.
  3. SXH
    SXH Well-Known Member
    Does it or the camera body need a firmware update?
  4. El_Sid
    No conflict between the lens OIS and the Olys sensor stabiliser is there?
  5. RovingMike
    Thanks for responses, sorry been inattentive. Firmware fully updated, both lenses on f8, but I take what you say on resolution. I keep thinking in film f11 terms.
    Might have been an OIS issue. I did switch it off after and have not got back for another test. Thanks will give that a go, but I think bottom line is the Oly lenses are hard to beat anyway. I bought the now discontinued little 14-42 II R as a backup for the Pen F for £100 on ebay and astounded that I can't see any difference with that.
  6. alfbranch
    alfbranch Well-Known Member
    The Leica DG 8-18 mm f2.8-4 is a superb lens
    I have not tried the lens in question but the 12-40 is hard to beat
  7. RovingMike
    I think that's the issue! Comparing with the best.
    alfbranch likes this.
  8. RovingMike
    I must say I'm enjoying using the Vario-Elmarit. That bit of extra reach makes all the difference. Hardly ever tempted to change to the 40-100.
  9. Snorri
    Snorri Well-Known Member
    And the image quality? Did you get that sorted?
