Best place to print landscapes (Himalayas - snow & rock)?
Discussion in 'Help Team' started by newbonic, Feb 13, 2017.
  1. newbonic
    newbonic Well-Known Member
    I recently went trekking in the Himalayas (Nepal, Annapurna region). I want to print a couple of pics to hang on the wall. I sent the full sized version of the pic below (taken on a Canon 6D with a 40mm pancake lens) to PhotoBox to print, and what looks like a vibrant 3d image on my PC monitor was just flattened and made dull and dead in the resultant 12" print that cost £5.
    Can anyone recommend a more specialist online printers that can do prints justice?
    Or should I just buy some premium print paper and have a go with Photoshop and my colour laserjet at home?
    This is 'High Camp' about 5000m up the Annapurna massif btw. It's the worlds highest footpath apparantly!
  2. EightBitTony
    I've had plenty of vibrant prints from Photobox. I always get some 6x4 prints done first, with a range of contrast / brightness settings, and find the one I like best before ordering full size (I don't have a proper colour managed workflow). The choice of gloss, matt, etc. from Photobox will also affect the output.
    Unless you can do some proof-print tests it will be a bit hit and miss. Presumably the autolevels processing that Photobox does has misjudged the mid-tones so the print has light bits and dark bits and mud in the middle. Try reducing the contrast and bringing the shadows up a bit and see if their print algorithm deals better with that. If the file is a jpeg then work on a cooy so as not to spoil the original.
  4. AlexMonro
    AlexMonro Old Grand Part Deux
    When I first started using Photobox I found some prints were a bit flat and dull, but after I used a basic monitor calibration website, I realised that I had the brightness up too high. After I turned the brightness down a bit I found the prints looked a lot better.
    EightBitTony likes this.
  5. cliveva
    cliveva Well-Known Member
    Always use monitor calibration, it may seem expensive, but saves a lot of "expensive" failed prints.
    Bobs Books is the best photo book printer I have tried,(Burb, Photobox) Whitewall have very good reviews.
    For single prints, I use my local camera shop, Cambrian Photography in Colwyn Bay, not that will help you, just giving them a recommend! But if you get it printed ,Face to Face, you can iron out problems with the finished print, if you can find an amenable printer.
  6. cliveva
    P.S. looking on my calibrated monitor, your starting point looks fine;)
  7. newbonic
    Thanks for the input folks. I think I'll look into getting a monitor calibrator in the first instance. And then print out a few 6x4 copies with different contrast/brightness & gloss/matt.
