Battery sizes
Discussion in 'Help Team' started by Dorset_Mike, Jun 22, 2017.
  1. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    I'm trying to source batteries for a Medion camcorder, it's 3.7V 720mAH; dimensions 35x40 mm, has numbers KLIC 7001 and NP 40, browsing Amazon there are quite a few NP40's most quote no dimensions, a few quote dimensions which seem more like the package size e.g. 10.2 x 2.5 x 20.3 cm ; am I right in thinking that NP40 refers to the physical size and the position of connections? Voltage is critical but mAH defines the amount of charge it can hold which in turn determines how long it will run on a full charge.
  2. Andrew Flannigan
  3. 0lybacker
    0lybacker In the Stop Bath
    Hi DM, try Googling The Small Battery Company and look at their web-site. Caveat: they haven't replied to my last e-mail for battery info, so I have been wondering if they are still in business.
    Seem to recall that down in Bournemouth or Poole is a guy who would build battery packs to order. Used to undercut Metz by refurbing 45 ni-cad cells. Cheers, Oly
  4. GeoffR
    A 3.7V sounds like a single cell Lithium ion device. There are many offerings of NP40 batteries and they should all be within a few 1/10s of a mm of the same size. As with all Li-Ion batteries, buy from a reputable source and choose a reputable manufacturer.
