Batteries for sb 800 - nikon
Discussion in 'Nikon Chat' started by Wiggie, Mar 21, 2012.
  1. Wiggie
    Wiggie Member
    What are the best batteries to use with my sb 800 flashgun please
  2. nimbus
    Personally I just use standard alkaline cells in my guns, buying a branded item, such as Panasonic or Energiser from the likes of Home Bargains where they run at 25p or less each. When they are exhausted they are then recycled.
  3. beatnik69
    beatnik69 Well-Known Member
    Some people recommend Eneloop batteries. Personally I'm with nimbus and use cheapies from the pound shops - You can usually get brands like Kodak or JCB.
  4. hech54
    hech54 Well-Known Member
    I personally also buy "cheapo-deluxe" batteries for my SB-600 but also have 8 Eneloops in my bag as well.
  5. GeoffR
    I buy AA batteries when I see them on offer, usually it is possible to find Duracell at around 30p each in DIY outlets and many places do their own brand. A battery's life in a flashgun is usually a hard one and almost any battery alkaline will do unless you expect them to last for several years or do a long shoot. Under normal amateur use it is probably better to leave the flashgun without batteries and fit them when needed.
  6. NosamLuap
    NosamLuap Rebmem Roines
    I use 2900mah NiMh rechargables (from 7dayshop), and recently started using their 'ready to go' range - these are like Eneloop (slow discharge, so retain their charge after being left for months). These are lower power (2100mah, IIRC) so recharge time isn't as quick, but both give me good service (several hundred shots per charge).
    They're about £4 for a pack of 4 inc delivery, and cost in very quickly compared with spending £1 for a set and throwing them away...
  7. beejaybee
    beejaybee Marvin
    Eh?
    Capacity has little to do with recharge time, in fact with the same internal resistance / charging voltage a lower capacity cell should recharge faster than a higher capacity one.
    Capacity has nothing to do with power output until the voltage begins to fall off as exhaustion is approached.
    Do you mean the Eneloops have a lower output voltage than the usual NiMH, or a higher internal resistance, or a lower charging current?
    For most purposes a cell which holds its charge better is superior to one with a larger capacity but with a shorter charge storage life. A week after charging the useful capacity of your "2900 mAh" batteries will probably be down to around 2100 mAh anyway.
  8. NosamLuap
    Doh - no, I was very unclear. When I said that the recharge time is slower with the 2100mah compared with the 2900mah, I meant the *flash* recycle/recharge time, not the battery recharge time. Sorry! The flash will recycle quicker with the 2900mah installed compared with the 2100mah. Not a massive difference, but if you're relying on speed it may be a factor in your decision.
    Absolutely - I bought the 2900mah sets before the slow-discharge type were readily available (at sensible money!). All my recent purchases have been the 2100mah slow discharge type - as you say, after a week or so they 'win', which suits my shooting pattern. It's very, very rare that I run down a set of batteries in a day; it's very common that I leave the camera sitting with the flash attached for weeks on end on the off chance the kids do something worth shooting. The slow discharge batteries mean I know that the flash will work when I need it to.
  9. Barney
    Barney Well-Known Member
    A word of caution Paul. Having two SB-900s I suffered from the infamous thermal cut-out 'issue' using 2700mah rechargeable batteries. Switching to the much lower rated Eneloops has just about solved the issue unless I really tax the little blighters (e.g. shooting iTTL & rapid refiring)
    The reason I urge caution is that the thermal cut-out on the Sb-900 isn't an issue, it's the Speedlight protecting it from possible damage through overheating. The SB-800 (and most other flashguns for that matter) has no such cut out and the first thing you know about any possible overheating is when it fries itself.
    Given my experience with the 2700mah batteries, I'm sticking to lower rated ones until I get chance to really test the theory.
  10. NosamLuap
    Good point... I use an sb900 too :)
  11. Wiggie
    Wiggie Member
    Thanks everyone for your comments - sorry for delay in replying - has given me some good ideas - wiggie
