24/4 - Worldwide Pinhole Photography Day 2016
Discussion in 'Forthcoming Events' started by Zou, Apr 8, 2016.
  1. Zou
    Just a reminder that as always, the last Sunday of April is Worldwide Pinhole Photography Day. It doesn't matter what gear you use so long as it is captured using a pinhole - digital or film, 35mm or 8x10.
    If you have an interchangeable lens camera and want to take part, you can make a tiny hole with the tip of a pin (who'd have thought it!) in aluminium from a drinks can and tape that over your lens mount. Imperfect results guaranteed!
  2. EightBitTony
    Make sure you dry it out thoroughly first ;)
    Pringles can (tin bottom type) for an even longer experience, although you'll probably need 20 minute exposures!
  3. Zou
    Just enough time to polish off the contents of the tube! :oops:
    EightBitTony likes this.
  4. Mark101
    Mark101 Well-Known Member
  5. 0lybacker
    0lybacker In the Stop Bath
    LOL! A little black paint will help improve the 'imperfect results' as will making a dent and filing the pip into the pinhole.
    The results might then look too good.
  6. Zou
    Anyone taken part yet? I've taken one shot so far and will stop off on my way home from work for a few more.
