Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Canal Reflection
    Nov 2009
    Canal Reflection
    Tried all sorts of compositions as wanted something different. Desaturated rather than mono. Your thoughts would be great. thanks.
    Please have a look and tell me what you think....
    http://www.flickr.com/photos/46180527@N03/sets/
    Ta!
    Aug 2007
    Somewhere under the raincloud
    Re: Canal Reflection
    I think a trim of the foreground of this image would tighten the composition up. That bare expanse of water acts as a bit of a distraction.
    Oct 2007
    UK, up North
    Location has great potential with a super reflection and that leading line on the left.
    However there is a great deal going on in this image. I might have gone for a quirky shot with a vertical cut through the arch and incorporating the graffiti, with reflection to its right. Top right quadrant only.
    There is also a nice composition on the left side, leading up to the lock gate through the bridge.
    Jan 2012
    Morecambe, Lancashire
    Is the graffiti blacked out by you?
    I like the shot and agree with the crop suggestion.
    Nov 2009
    thanks for the replies guys. really wasn't sure where to put the reflection and where to crop the bottom and can see why the crop would make sense. only reason i left it like this was it has the path controlling the corner of the shot and seems a little stronger for it. but then like you say there is plenty of cloud. wanted to leave some cloud and didn't want to go too pano.
    the black bits are all original.
    this composition has been a headache!
    Ta!
    Feb 2010
    Quote Originally Posted by nimbus View Post
    I agree some cropping would help with the balance of the image.
    Feb 2007
    Edinburgh
    Don't want to see the reflected sky, and shame the arch it is so central. Like the desaturated colour and the contrast though.
    Nov 2009
    any better? would go no sky at all but as the brick work above stops where the shot does, it would be too narrow.
    tried all sorts of crops and compositions but this was the only one i was happy with. was kneeling on the path with nex5 held above the water.
    Ta!
  9. #9
    Aug 2007
    I would crop the bottom a bit more, the glare is still a distraction.
  10. #10
    Feb 2007
    Nottingham
    I know you didn't want to go panoramic but I feel it might work
    David
    We are here to learn.
  11. #11
    Nov 2009
    thanks for the replies guys. only reason didn't want to go pano is that i wanted to challenge myself to find a composition that would work without doing that. think it may be only option. will post a crop once at my pc. thank you all.
    Ta!
  12. #12
    Nov 2009
    Pano crop...
    Ta!
  13. #13
    Feb 2007
    Nottingham
    that's ok
    David
  14. #14
    Aug 2007
    I don't think I would have gone quite this far, I would try leaving a small amount of the brighter looking area to include the top of the bridge in the reflection.
  15. #15
    Nov 2009
    shame the wall wasn't higher as would have given much deeper reflection and more space around the bridge opening. have tried all sorts of angles etc and although this is the best one, its still tricky. will post a final crop with a touch of sky, nimbus. thanks again.
    Ta!
  16. #16
    Nov 2009
    less sky...
    Ta!
  17. #17
    Aug 2007
    Just a little bit more off! About half the distance between the bottom of the frame and the highest point of the bridge will do nicely
  18. #18
    May 2006
    Shenley, Herts but about to move to Tadworth, Surrey
    ifc1892's crop for me.
  19. #19
    Nov 2009
    will oblige and post in a while...
    Ta!
  20. #20
    Nov 2009
    Quote Originally Posted by RovingMike View Post
    thanks for the reply, Mike. do you mean the original crop or the last one?
    Ta!
