OK, so I can understand that the 1.5 crop factor makes a lens with a focal length of 50mm appear to behave like a lens with a focal length of 75mm when mounted on a DSLR. In real terms its focal length of course remains 50mm.
What I don’t understand is whether this has any effect on the ratio at which an object appears on the sensor of a DSLR as opposed to a frame of film and the resulting negative. I’ll use as an example the lens I’m thinking of buying: the Tamron 90mm F2.8. I can see on a DSLR with a crop factor of 1.5 this will behave like a 135mm F2.8, but will it still reproduce an object at life size (1:1) or larger or smaller?
