Results 1 to 4 of 4
Thread: Leica R versus Leica M glass
    Jul 2005
    Milton Keynes, UK
    Just wondering whether the magic of Leica glass extends to the lenses they sold for their SLRs, and whether I'd get similar results using a Summicron-R on an R4 say, as from a Summicron on an M3. I can't recall this being discussed, and there does seem to be a cost advantage in favour of the R ranges.
    Or is the magic much more to do with the different way in which an RF Leica is handled cf an SLR?
    Many thanks - from a nearly 100% dyed in the wool SLR user.
    Malcolm Stewart
    Jaguar Mk VII
    Junior Member
    Mar 2006
    Derbyshire
    Re: Leica R versus Leica M glass
    I still use film for most of my work and it's with M's and R's. The R glass I use is mainly the Minolta derived zooms (35-70 MkII; 70-210 f4) and while they are not as sharp as the M series (assuming I've not shaken the camera!) the colour rendition means I can mix the slides together in a show without any problems. I think the R series offers some pretty good bargains at the moment given its original prices - I've seen R8's going for £300 - £350 and I paid £240 on ebay for the 70-210 and £300 from a retailer for the 35-70. You can get an f2 Summicron 50mm for less than £200 depending on condition. You can't get an M 50mm Summicron for that and I think they stand comparison.
    Just my views, hope it helps.
    With as stony a stare as ever Lord Reith could have conjured up... TimF's Avatar
    Jul 2001
    Herts/Beds border
    It all depends on the glass, and what you want to use it for. As with all systems, some lenses are better than others.
    My R glass (mostly bought s/h) consists of the 19mm f/2.8 ROM, 35mm f/2, 50mm f/2, 60mm f/2.8 Macro, 80mm f/1.4, 90mm f/2 APO, 100mm f/2.8 APO-Macro, 180mm f/2.8 APO v.2, 280mm f/4 APO and 400mm f/6.8.
    Of those, the lenses from 90mm to 280mm can stand comparison with anybody else's, and probably beat most of them for IQ. The 80mm is a classic, and Leica lovers go for it for its signature. Yes, it's a little soft at widest apertures, but for portraiture work for example, is that a problem - too sharp a lens can be unflattering. I haven't tested it against the light, but the 80mm is said to be extremely flare resistant.
    The 60mm is also a very fine lens despite its age (first available 1972). For a wide angle prime, the 19mm is probably only rivalled by Leica's own 15mm R, and by the two Zeiss 21mm lenses (for Contax and the ZF/ZE range). The latest Zeiss is probably the best.
    The 35mm is probably the weakest of the glass I have - it's not great in the corners; the older f/2.8 is better - but on the DMR with its x1.37 crop that isn't an issue really. The 50mm is a good performer, but no better than similar offerings from Canon, Nikon etc (for top class there you'd need to track down the uncommon 50mm Summilux-R in its final form).
    The 400mm is a very old (and simple, just 2 elements) design. It still gives a decent, if not outstanding performance though.
    One final word, you do need to be aware that R lenses come in various versions, single cam, 2-cam, 3-cam, R-cam and ROM. For the 'proper' R-series bodies, ie R3 onwards, you need a 3-cam, R-cam or ROM lens. The older lenses are for the Leicaflex bodies. The 3-cam lenses can (mostly) be used on all Leica SLRs, but the R-cam and ROM types lack the cams to use them on the Leicaflexes.
    Some of the designs for R and M lenses do have some commonality; the 75mm Summilux-M and 80mm Summilux-R are basically the same design for example.
    If you're fishing Malcolm, I would certainly say that a cheaper R body and a lens (forgetting the Minolta and Sigma derived zooms - stick to the 35-70mm f/4 and 80-200 f/4 for example. The best 'real" Leica zooms such as the 28-90mm f/2.8-4, 70-180mm f/2.8 and the short-lived 35-70mm f/2.8 are still ferociously costly) would be an inexpensive way to dip your toe into the Leica world.
    Tim BSRIPN
    Jul 2005
    Milton Keynes, UK
    Thank you both for your informative replies.
    There's some very useful information for me which I must try to have with me so that I'm not tempted by the wrong items at my next visit to a Camera Fair, or even Focus next week. Tim's info on zoom versions and cams etc. will be most useful.
    I still have my Minolta X700 (and the SRT101 which got me into serious SLR photography) and the Minolta 35-70 zoom, and I've plenty of Kodachrome slides from that combination. I think I bought the zoom from my local Boots when they decided that they were getting out of half-serious photography.
    Malcolm Stewart
    Jaguar Mk VII
