Results 1 to 8 of 8
Thread: IR film and a Trip 35
    Member
    Apr 2008
    The sun kissed beeches of Nottingham
    Will it be in focus at all? My head says no, but my heart wants to say yes.
    Senior Member zx9's Avatar
    Jun 2007
    London
    Re: IR film and a Trip 35
    I would think that the 35mm (?) would have sufficient dof to render the IR focus not too far out. How the selenium meter cell will like to be hidden behind an IR filter may be another matter!
    Regards,
    Keith Hudson - ZX9
    Member
    Apr 2008
    40mm at f22 is it's deepest, and it'll be 1/40s whatever the lighting conditions.
    What I didn't think about is it's low light mechanism that stops the shutter firing when it's too dark (ie: in your bag, or with the lens cap on), so an IR filter will probably upset that. Maybe a half press, and then putting the filter on?
    Member
    Apr 2009
    Stafford
    You would need to use the aperture setting on the lens rather than leave it on "A" as you would for flash photography. This locks the camera to 1/40th sec shutter speed but disables the low light lock so the shutter will trip in any light. If you set a smallish aperture, the DOF should cater for the IR focussing difference.
    Good luck finding a 43.5mm IR filter
    "Stuck in the seventies"
    Member
    Apr 2008
    Member
    Apr 2009
    Stafford
    I may be being dense/blind, but I cant see a 43.5mm stepping ring in either direction in that list! Though they do exist on other sites
    Member
    Apr 2008
    43mm and a bit of plumbers tape. Job done. I don't know, you kids today, expecting it all on a plate for you....
    Member
    Apr 2009
    Stafford
    I s'pose as IR film is a bit fuzzy anyway it won't matter if the filter is misaligned.
