Results 1 to 4 of 4
Thread: efs 18-55 is
    Junior Member
    Oct 2009
    efs 18-55 is
    thinking of getting the above for about 100 quid new is it worth getting as i havent got anything smaller, or is it worth saving a bit more to get perhaps a better prime lens, i already have a 28-200 and an 85mm just wanted something i could use for limted space for portraits at home?
    Senior Member El_Sid's Avatar
    Apr 2003
    Sussex-by-the-Sea
    Re: efs 18-55 is
    Any kind of prime lens wider than 28mm is likely to cost you considerably more than £100 used let alone new - especially anything as wide as 18-20mm. Unless you expect to do a lot of work in confined spaces the 18-55 IS is probably good enough.
    Completely BSRIPN
    The New El Sid Gallery or
    The El Sid Gallery 2
    Junior Member
    Jun 2008
    Re: efs 18-55 is
    I believe you can get the 18-55mm IS a lot cheaper than £100 on eBay........
    Aug 2000
    Everywhere and nowhere, baby
    Re: efs 18-55 is
    I rather like the 18-55 IS - it's an absolute bargain, and a decent enough performer.
