Results 1 to 3 of 3
Thread: Images soft using Master 2
    Junior Member
    Aug 2006
    Does anyone else find that images are very soft when viewed as a slide show using Master 2 ?
    Maybe i'm missing something in the settings but any help would be appreciated.
    Rick
    Mar 2007
    Reading , Dorset or York
    Re: Images soft using Master 2
    Just done a test and could not detect this problem. The ones I tried it on were all JPGs - were yours RAW or JPG? if JPGs do they look better in another viewer?
    Roger
    Senior Member El_Sid's Avatar
    Apr 2003
    Sussex-by-the-Sea
    Not sure if the same will apply to Master 2 but when viewing images as a slideshow in Canons software or Adobe Bridge the slides often look a bit soft although they process OK and are sharp enough when viewed in PS (except where I've made a cock-up ). I suspect that the apparent softness is down to interpolation erroe when the software recalulates the full size image to the screen size used for the slide show.
    I now try to assess sharpness/focus at 50% image size which I find more representative of sharpness at normal print sizes.
    Completely BSRIPN
    The New El Sid Gallery or
    The El Sid Gallery 2
