Results 1 to 7 of 7
Thread: Manfrotto tripod
    Jan 2010
    Manfrotto tripod
    Hi
    I have an old ish Manfrotto 0550 c tripod in perfect condition , as I remember there is a way to turn it into a monopod but cant for the life of me remember how any help would be greatly appreciated.
    Thanks Greg
    Apr 2006
    Devon, UK.
    Re: Manfrotto tripod
    Easiest way would be to simply extend just one leg of the tripod and strap the legs to the centre column to stop them splaying out.
    MATWSIJ.....
    Jan 2010
    there is a way of actually turning it into a monopod tho . I am positive
    Greg
    Aug 2004
    SE England
    I have the 055Pro and there's no way, short of removing two of the legs, to turn it into a monopod. Removing the legs would not be easy therefore I assume that Manfrotto didn't intend that to happen.
    I'm sorry if my model is completely different from yours. If it is then this reply is rather pointless.
    MickLL
    Jul 2007
    Really Here In Name Only
    Hacksaw? Jaws of Life?
    I couldn't find the model number you quoted on the Manfrotto website. The link below is for the 055c.
    Deleted in 1999, it appears to show only one leg. Did this tripod require assembly when first purchased, and that is what you remember?
    I would just extend one leg, or buy a monopod; some can be had for quite reasonable sums (though I appreciate that may be relative).
    Good luck
    www.manfrotto.com PDF
    Live long, and prosper \\ ///
    I'd give my right arm to be ambidextrous
    my website
    Jun 2003
    Lancashire
    I used to have that model. I'm not aware of it being able to convert to a monopod but you could remove the centre column and shorten the column.
    ...it appears to show only one leg. Did this tripod require assembly when first purchased...
    I think the diagram shows one leg for clarity in order to illustrate the part numbers. My tripod was ready assembled straight from the box.
    Richard...
    My Flickr | My Website | My Blog
