I've just got my first scanner (an Epson V500) up and running and I've been feeling my way around the various menus and options. I scanned a picture of a cat from a magazine page to assess for myself the resolution on my monitor (the magazine picture looked particularly sharp so I thought I might view fur and whiskers at hi-res to assess results).
I started with settings of 24-bit at 1,200 dpi but when I tried to open the resultant jpeg it said the file (24MB) was unopenable or might have been damaged or corrupted - why was this do you think?
I tried again at 720 dpi and the resulting scan was successful and looked pretty good to me (jpeg file size had reduced to 7.4MB in the process).
I've already discovered that scan times are dependent on the resolution setting, so when it comes to scanning old photographs for eventual digital aftercare, what would you suggest is the optimum resolution setting I might use to produce decent quality photographs from the jpegs generated by the scanner?
Another learning curve here I know, but I catch on pretty fast!
Rupert
