Results 1 to 5 of 5
Thread: OM1n hot shoe wanted
    Dec 2009
    Does anyone know how to get hold of an OM1n flash shoe please. Mine's cracked and now lost.
    Jan 2007
    East Yorkshire,
    Re: OM1n hot shoe wanted
    is this any good................?
    http://tinyurl.com/OM-1-hotshoe
    Apr 2009
    Stafford
    No-the accessory shoe 1 is only suitable for the OM1-the OM1n needs a shoe 4 ( see here ) E-bay is probably the best place to look, but being cracked is almost normal as the shoes are really not strong enough for the load a flashgun imposes.
    "Stuck in the seventies"
    Jul 2007
    Really Here In Name Only
    Just like togs in general
    Actually the problem with the Oly screw-on hotshoes is that cracks spread from the sharp corners inside where they fit over the pentaprism "hump" due to the fixing screw being overtightened. The corners should have been rounded to spread the stress instead of concentrating it. Usually the electrical connections work just fine despite the cracks, though a camera which has had its hotshoe removed for a long period may have corrosion on the contacts.
    Expect to pay big money for an "uncracked" hotshoe, they're very rare ... and expect to find that a proportion of used hotshoes sold as "uncracked" actually bear cracks, when inspected with a magnifying glass.
    The cracks form when the fixing screw is overtightened. Nothing to do with the load imposed by a flashgun.
    Apr 2009
    Stafford
    The problem being that unless the screw is overtightened the shoe/flashgun assembly tends to wobble alarmingly when fitted with any but a tiny flashgun-and once the cracks start the wobbling gets worse necessitating more tightening to control it. Personally, I believe the cracks start as a result of side to side movement of the shoe with a gun fitted-and are then worsened as the owner tightens the screw in an attempt to control it!
