I had been looking for some time for an eight pin 1.7x tele-converter for my Dynax 7 and KM 28-75mm f2.8 D, to extend the possibility of using ADI up to 120mm. I found one on ebay.de at a good price, so grabbed it. Unfortunately, it is not chipped, just straight through connections. Obviously, this is not a problem for exposure, as the loss of 1.5 stops will be self correcting - the ratio of used aperture to max aperture remains unchanged, despite the effective aperture being incorrectly reported to the camera. Nor is the focused distance a problem, as the reported distance will be the same with or without the converter (although the DoF will be calculated incorrectly). However, having been unable to find a detailed description of how ADI works, I have assumed that the recalculated guide number will instruct the flash to deliver the amount of light required at the incorrectly reported aperture - 1.5 stops too little, in fact.
So, if my assumption is correct, then I simply have to set +1.5 stops on the flash exposure compensation, and Robert is your parent's sibling's brother.If, however, the final light from the flash is TTL based, then I don't need to compensate.
Unfortunately I don't have time to experiment and get the film processed before Saturday, when I had plans to use it in anger, as it were.
Has anyone with more experience of Minolta than I have, got any bright ideas? Many thanks!
