Results 1 to 5 of 5
Thread: Church x 1
    Member
    Mar 2009
    South Devon
    Church x 1
    The photo below is our local church. I am having problems trying to stop it looing like its going to topple over.
    I have had a go using Elements 6 but just get everything to line up.
    Link to original untouched photo
    Colin
    Junior Member
    May 2008
    Re: Church x 1
    Hi JediKnight
    did this in elements 6 in the following manner:
    Image, Transform, Distort,
    Pulled the top left corner into a position on the left to square it up. Also used the magic wand to select the sky and used levels to adjust.
    Hope you did not mind the edit but i hope this was the answer to your question, and helps you.
    Did not spend more than a couple a mins with image.
    Regards
    Alan
    Senior Member 4BIKER2's Avatar
    Feb 2008
    West Midlands
    Re: Church x 1
    Using your original picture and the left hand side of the center tower ( near to the center of the picture ) as a guide, rotate the picture 2.83 degrees counter clockwise, or until it looks right and crop.
    The learning curve is so steep I keep falling off.
    Jul 2008
    edinburgh
    Re: Church x 1
    Sometimes less is more!
    That was all it needed IMVHO. Looking good.
    Kenny.
    Member
    Mar 2009
    South Devon
    Re: Church x 1
    Thanks everyone for your help, much appreciated
    Colin
