Results 1 to 15 of 15
Thread: Push-pull or twist-zoom, is one better?
    Member
    Dec 2006
    East Coast
    I have a Nikkor 35-70 push-pull 'zoom' lens, which I like very much. I know it's good quality and sharp.
    I have some that are twist to zoom which are also good.
    Just curious, is one design superiour to the other, or is it simply a matter of cost-to-produce?
    Cheers!
    AD
    So rise up, o ye lost ones
    As one we will claw the clouds
    Rise up, the forsaken and dethroned
    A legion wronged, to claw the clouds
    Jul 2008
    edinburgh
    Re: Push-pull or twist-zoom, is one better?
    Some "push/pull" types,if "weighty" can creep from one focal lenth to another, while the camera is still hanging around your neck.
    The more a lens is used, the more chance of this type of "zoomcreep"
    Optically, I don't think either lens type automatically makes it a "better" lens
    Kenny.
    May 2003
    Bucks
    Either type can "creep" it really is just a matter of personal preference for the user and convenience for the manufacturer. Though some physically long zooms could become almost impossible to use if they aren't of the "two touch" variety.
    Aug 2000
    Everywhere and nowhere, baby
    Back in the late 70s, the trombone type were generally much preferred for their speed of use. In the AF era, the two touch type are dominant because of greater precision. I was playing with an old Nikkor 100-300mm f5.6 yesterday, a trombone type, and it's very nice.
    Senior Member El_Sid's Avatar
    Apr 2003
    Sussex-by-the-Sea
    I have several zooms in both types and I think I'd just plump for the two touch type as better overall. Most of my one touch (push-pull) types are a bit stiff in operation and a bit tricky to zoom with precision while on the whole the two touch types are better in this respect - although as with most things the original cost, and thereby build quality, tend to have a bearing on ease and precision of use.
    Perhaps the exception to this is my 70-210 f4 Series E Nikon which has a very nice and easy-to-use slide - although inevitably it can creep quite a lot if angle up or down too much and not held in place...
    Completely BSRIPN
    The New El Sid Gallery or
    The El Sid Gallery 2
    Jul 2005
    Milton Keynes, UK
    All zooms which change length must act as dust suckers to some degree - the only zoom I have which is fixed in length is my EF 70-200 f4L. Does it matter, probably not in the UK, but in countries where there's dust storms with fine sand, it's a serious issue. (Gets into the USM mechanisms as well if they're not adequately sealed.)
    Malcolm Stewart
    Jaguar Mk VII
    Oct 2007
    Swansea, Gateway to Gower
    I have a Sigma 70-210 f4 one touch zoom,which is in Fuji x mount,now unusable since I have no functioning camera on which to mount it.While optically sound,it has always suffered from zoom creep.It must be a design fault.
    Dave NRIPN
    my flickr
    Apr 2003
    Sussex-by-the-Sea
    The problem with zoom mechanisms is that they have to be a compromise design to some extent. Too tight and the lens is difficult to zoom smoothly and with precision, too loose and it creeps. As I said above my Series E Nikon zooms very smoothly but does creep quite easily while my much tighter Tamron 200-400 doesn't creep much if at all - but is very difficult to zoom precisely. It's all a matter of swings and roundabouts though, as with much else, I suspect that the more expensive and well constructed a lens is the closer to ideal the compromise becomes.
    PS the Nikon E isn't the lens with the worst creep that I have - that honour must go to an aged 35-135 USM Canon which I have previously described as not suffering from zoom creep so much as zoom sprint... In this case I suspect it's a combination of poor design, mediocre build quality and sheer age - boy is it loose...
    Completely BSRIPN
  9. #9
    Feb 2002
    Môn mam cymru
    boy is it loose...
    I had an ex-wife like that!
    JustMono
  10. #10
    Member
    Mar 2004
    Brussels & Chester
    Yes you are right. I had not thought of it before but in manual focus days the 2-touch zoom was deprecated. I had a 80-200 f2.8 that I bought s/h mint for next to nothing because it was 2-touch (ok it was a konica mount) so I never used a one-touch and was happy to be different. Now with AF the 2-touch is a de facto 1-touch. Thank you for the insight!
  11. #11
    Senior Member Zou's Avatar
    Feb 2007
    Edinburgh
    I have a one-touch 70-200. It works fine when at either extreme (either 70 or 200) but inbetween fine focus is difficult without accidently changing the focal length. I much prefer a two-touch if it has to be a zoom.
  12. #12
    Member
    Dec 2006
    East Coast
    Can you kindly explain what the term "one touch" and "two touch" mean? Thanks
  13. #13
    Senior Member Wheelman's Avatar
    Nov 2002
    Kent/Sussex border
    Term used on manual focus zooms that have sort of carried over......
    One touch is a push-pull zoom as you hold it in one position and twist to focus and push/pull to zoom
    Two touch is where there are two rings, one twists to focus the other twists to zoom
    nowadays with auto focus they are both theoretically one touch as you either twist or push/pull to zoom and the camera sorts out focussing. (unless you turn AF off of course )
    Hope this helps
    Colin
    IRIPN
    When you don't know where you are going then any road will do
  14. #14
    Persona non grata
    Sep 2008
    Reading, Berkshire UK
    I would guess that both 'systems' have their plus and minus points;
    The Push-pull versions offer focus-override (when it's an AF version) and zoom adjustment via a single control and some of these also have a DOF markers on the barrel assembly. However, I would guess that over a period of time these optics become 'dust-suckers' due to wear and tear upon the seals used.
    The versions with 2 twist rings, may well be 'ergonomically' less satisfactory to some people, because it uses two rings and users could well end up accidentally rotating the 'wrong' ring. However, they may well be less prone to dust-sucking because the mechanism moves around inside the main barrel.
    The internal design of the 2 ring zooms, are likely to be more complex, but I would guess only a lens designer would be able to tell you which of the 2 systems, imposes the least compromises due to the accuracy required in positioning the various elements where they need to be.
  15. #15
    Marvin beejaybee's Avatar
    Jul 2007
    Really Here In Name Only
    This is a question of how much the volume changes when the zoom is operated, not the mechanism for working it. Many two ring action zooms suck in or blow out a considerable volume of air when the zoom is operated, and some push/pull & twist action zooms don't.
    The basic issue is that push/pull & twist action doesn't work with AF motors unless a "continuous MF" clutch mechanism is used, and using the same ring for zoom & focus with a USM type AF drive is asking to get the focus wrong when users don't realise that they're inadvertently over-riding the AF focus mechanism when zooming whilst half pressing the shutter release. Push/pull & twist makes lots of sense when focusing manually, to the extent that two ring action zooms looked like becoming an endangered species until AF became dominant.
