Results 1 to 11 of 11
Thread: Macro focusing with G10 - can't get it right!
    Senior Member gray1720's Avatar
    Jan 2009
    Oxford
    Hopefully an experienced G10 user can tell me what I'm doing wrong... As the manual seems to suggest that you can focus as close as an inch from the lens, I thought I'd try to take a photo of a bee orchid today. However I just can't get the blessed thing in focus, keep getting the grass several inches behind in focus and, when I press the shutter button, the autofocus (according to the screen) promptly defocuses! It's currently seriously tempting me to break the Box Brownies back out...
    I've tried setting the AF mode to centre, with no luck. I presume that I'm missing something obvious (like the digital teleconverter mode) or the AF light is missing the subject so close up), as that usually seems to be the case. Can anyone put me out of my misery and tell me what I'm probably doing wrong?
    If the EXIF data will help, I'll post a pic tomorrow.
    Thanks,
    Adrian
    All part of the fun of extreme vintage photography
    You'll be amazed at the carp I've posted here: http://www.flickr.com/photos/gray1720/
    Senior Member jchrisc's Avatar
    Jan 2003
    Ampthill, Bedfordshire
    Re: Macro focusing with G10 - can't get it right!
    I suppose you have actually switched it to macro mode? The little flower symbol?
    My memory is getting worse . . . and my conscience clearer
    Junior Member
    May 2008
    Hi Adrian
    I have a G10 and the G10 can be a bit of a pain to get macro to work as you say above, settings are as follows:
    if you are using the creative moads like P, Tv, Av, M, C1, C2, on the top dial, look at the function dial on the back press the Macro button (flower) amd it brings 2 pics on the screen Normal (mountain) and Macro (flower) you have to change it from mountain to flower with the outer dial in the function dial area and select flower and press function set (centre)
    if you use the Auro or SCN modes you use the same settings as above.
    hope this helps. if you need more details, or clarification, just ask.
    Regards
    Alan
    Senior Member zx9's Avatar
    Jun 2007
    London
    If the G10 is like the G9 it will focus closer and give bigger magnification with the zoom set to the shorter focal lengths (obvious if you think about it but took me a while to work it out).
    Taken on my G9 the insect was about 50mm away from the lens.
    Regards,
    Keith Hudson - ZX9
    Jan 2009
    Oxford
    Yes, I have. I'm not (quite...) that daft! Well, not in this case, at least.
    Alan, I'm pretty sure that that is what I'm doing already, though I've been working from auto rather than the "creative modes" to try and cut down what I'm having to do while I find my way round the camera. Possibly that's a mistake in itself?
    Adrian
    *Edit* - zx9 posted while I was posting my reply. I can't believe that Canon would reduce the capabilities between the G9 and the G10. That tends to make me think I'm missing something. Maybe it's the shorter focal lengths - will have to have another fiddle, I think.
    Hinkypuff ermintrude's Avatar
    Jun 2003
    London, UK
    In the S series you can't use Macro in Auto mode, so I suspect its the same with the G series...
    (Ctrl A > Ctrl C )
    Senior Member Bettina's Avatar
    Feb 2004
    London
    With the G9 you can't really focus and zoom in macro mode. It works fine at the default seting eg 28mm.
    Jan 2009
    Oxford
    Cheers for the pointers, everyone. Looks like I need to go away and have a good fiddle with it to work out what it actually does.
    No doubt will be back with another dumb question soon...
    Thanks,
    Adrian
  9. #9
    Jan 2009
    Oxford
    Hurrah - sort of! It finally focused close today (and stayed focused when I pressed the shutter...), on a tiger moth on the other side of the window. Nowhere near as tight as zx9's 'hopper, but I'm on the right path. I guess I expected that I could hold it a bit further away and zoom in - too much time with a borrowed Tamron 90mm SP, obviously!
    Thanks for the help, now just need some time to practice!
    Adrian
  10. #10
    Jun 2003
    London, UK
    Adrian
    No you cannot zoom on Macro or use Auto. Glad its working for you now
    (Ctrl A > Ctrl C )
  11. #11
    Apr 2003
    Just West of Norwich, Norfolk
    Very helpful tutorial everyone. Thanks.
    i really love my G10 to bits!
    David.
    Photos hosted by Flickr.
