Absolutely not. I want the sensor firmly nailed to the body,
WHS, with knobs on. Nailed, bolted down, tied to a humungous great block of granite, and the foundations sunk 200' down into the bedrock. :-)
Apologies in advance for this next bit, but it has to come out.
<u>
WARNING: MAY CONTAIN RANTS</u>
The thing about shift is it's not really necessary in the digital age - the small amount of software correction needed for converging parallel lines is really neither here nor there from a quality point of view unless extreme corrections are necessary - in which case (a) the lens mounts aren't wide enough to incorporate the amounts of shift that would be needed to do it optically, (b) the large image circles needed mean that the photographer will be losing large amounts of optical quality anyway, off-setting gains made by foregoing the resampling done by software correction, and (c) reintroducing all those bad corner issues - vignetting, fringing due to extreme incidence angles on the microlenses and anti-aliasing filter, smearing due to photons being captured in wells adjacent to the ones they should be in, and so on.
And then there's tilt - absolutely essential for large formats, where depth of field is practically non-existent, but almost totally over the top for small formats. Even for 'full-frame', which now seems to have established itself as the largest format in common use, and to have replaced, say, medium format, as the one that enthusiasts commonly aspire to, it's really pushing it.
The buzz on internet forums these days seems to imply, sometimes, that no self-respecting manufacturer's lens inventory would be complete without a swathe of T&S lenses covering ultra-wide right through to moderate telephoto. The usual gleeful 'new toy' threads appear whenever someone gets hold of their new baby, and what do we get from them? Bl**dy mock 'toy-town' shots! That's all these small format T&S lenses have done for photography in the digital era. Tilts used to be all about making best use of the little DoF that was available on large format - now the formats are comparitively tiny, DoF is much greater by default, and some other justification needs to be found for an expensive and highly specialized piece of kit - enter the 'reverse tilt', where the goal is to get everything apart from the subject as out of focus as possible, producing the toy-town effect. And if I see one more of them I might just start to develop a fondness for That Bl**dy Mountain, and bluebell wood shots - I'm that p*ssed of with them!
That's it. Thank-you. All over now.
