Results 1 to 18 of 18
Thread: External drives
    Feb 2002
    Môn mam cymru
    External drives
    I am looking hard at this; LaCie 1TB Little Big Disk Quadra eSATA
    Does anyone have any experience with this manufacturer?
    JustMono
    Marvin beejaybee's Avatar
    Jul 2007
    Really Here In Name Only
    Re: External drives
    LaCie ... the innards are just the same as everyone else's; a random selection of what they could get cheapest at the time. The brand has a reputation for being reasonably reliable but significantly overpriced for the specification. (Think Nikon as opposed to Vivitar or Leica). Styling is personal. Whether the price represents good value for you is your choice not mine.
    Senior Member jchrisc's Avatar
    Jan 2003
    Ampthill, Bedfordshire
    Re: External drives
    I bought their 500Gb external drive some time ago without realising that it actually held two separate 250Gb drives with software that made it behave like a single disc. Nothing serious ever went wrong with it, but the software was temperamental and I had to be careful about the switching-on routine or it would fail to boot.
    My memory is getting worse . . . and my conscience clearer
    Feb 2002
    Môn mam cymru
    Re: External drives
    Thank you both, caveat emptor indeed
    I will continue trawling through other maker's wares.
    JustMono
    Mar 2008
    Bedfordshire
    Re: External drives
    I recently got a WD 1TB Mybook eSATA, which didn't function at all on eSATA.
    USB/Firewire was fine, and the eSATA was sometimes detected in BIOS, but always hung the system.
    Checking out some reviews, it seems that it is a common thing with these disks, so I sent it back and am now looking for something else.
    eSATA is definitely the way to go - I guess I'll look at Seagate or something similar.
    The worst battle cry I ever heard - "Look out! He's got a bigger camera!"
    Formerly deddard
    Gorgeous oversensitive Nikon-loving cream puff BigWill's Avatar
    Sep 2000
    Northern Ireland
    Re: External drives
    I've got a Maxtor 500gb external drive Peter. It works a treat with no problems at all and even comes with a three year guarantee...........which is nice!
    BigWill
    I'm sailing like a driftwood on a windy bay.
    Mar 2002
    London'ish
    Re: External drives
    I've got a LaCie 500GB external USB drive. Never had any problems. Had it 2yrs now
    Margaret Atwood
    Feb 2002
    Môn mam cymru
    Re: External drives
    Thanks Will and Fen, all information very welcome before lashing out.
    JustMono
  9. #9
    Senior Member Ian_A's Avatar
    Sep 2002
    Lancashire
    Re: External drives
    I generally buy an external housing like this and stick whatever drive I like in it.
  10. #10
    Alpha Napper RonM's Avatar
    Apr 2001
    Scotland
    Re: External drives
    Like Ian I have similar boxes with IDE and SATA drives and use MS SyncToy to back-up images and data
    Ron BSRIPN
    Feb 2002
    Môn mam cymru
    Re: External drives
    IDE - SATA?
    Oh Ron, I'm older than you, you know and definitely a lot thicker. Are these different types of drive?
    JustMono
  12. #12
    Member Meredith's Avatar
    Oct 2006
    Coventry, UK
    Re: External drives
    IDE and SATA are hard disk interfaces. SATA is replacing IDE.
  13. #13
    Senior Member pachinkofan's Avatar
    Aug 2005
    Just North of Montrose, Scotland
    Re: External drives
    IDE's the old style "ribbon" cable (80 pin), SATA's a new different faster connection which only has 4 wires, but then there's also SATA II which is even faster. You can get a cable etc to change an IDE motherboard to be compatible with SATA, but I don't know how well it'd work.
    little bit of clarity
    G>
    Garry
    Nights were a real drag, thankfully work's on 2 shifts now [day/back] so more time to do things... If only photography were higher up the pecking order ;-)
  14. #14
    Sep 2000
    Northern Ireland
    Re: External drives
    I had (still have actually) one of those as well but it always concerned me that you switch them on and off from a simple power switch or that they simply stop when you switch your computer off if you leave the switch in the on position. I mean you wouldn't switch your computer off and on from the power switch as it might damage the HD doing that and so why would you do it with an external drive? My Maxtor has a "power up/down mode" as well as a standby mode which to my mind seems to be much kinder to the drive..................though having said that I never did actually have a problem with my old cheapo external HD enclosure! .............just a thought though. Whaddya reckon Ian?
    BigWill
  15. #15
    Sep 2002
    Lancashire
    Re: External drives
    wibble.
  16. #16
    Senior Member digitravel's Avatar
    Dec 2002
    Dorset
    Re: External drives
    Ive had Lacie externals and portables for a few years as well and never had a problem either.
  17. #17
    Oct 2006
    Cumbria and Buckinghamshire
    Re: External drives
    I have one of these LaCie 1TB Little Big Disk Quadra eSATA and it seems to work OK. I have two similar LaCie drives which are getting somewhat old now. As I like the cases does anyone know whether I can just replace the two drives?
    An alternative to the packaged hard drives is to use docking stations, see here:
    http://www.maplin.co.uk/Search.aspx?menuno=12756
  18. #18
    Feb 2002
    Môn mam cymru
    Re: External drives
    Thank you everyone. A whole new language to learn but it's all fun isn't it?
    JustMono
