June - "Man-made landscape" - the urban jungle
Cityscape, town planning, the heart of the village, industrial wasteland, shopping heaven. Photograph the man-made world as you would the hills, looking for the shapes, the textures and the undulations. Use the light and make Charlie cry..
1. PLEASE DO NOT POST IMAGES until you have read the Posting Images – Maximum Sizes etc sticky on this forum.
2. Images must not exceed 600 pixels x 600 pixels
3. File sizes must be under 100kb (102,400 bytes) – right click on your image then Properties to check the image and file size are correct before and after posting.
IMAGES THAT DON’T CONFORM TO THESE RULES WILL BE DELETED! Do not post TWICE in the comp - ask a moderator to correct or alter your original entry if you are having a problem.
4. Images must be displayed in this thread (click on reply in this post and put your link in the Image tag in the Mark-up section of your post). - Note: Image must end in .jpg to display
5. Images must have a suitable title in the subject line.
6. No links please – images must be displayed in this thread only! (Technical details should be kept to a minimum)
7. One entry only per person is allowed. If you need to change it, please contact a moderator with new URL and reason why. Note: bear in mind that changes to the monthly comp are not continuous and should be used only as a last resort.
8. If you don't have a resizing program, Download this FREE program (Pixresizer) --- See my visual on how to use it
PS. If you're new to embedding images in forums and you're having problems, don't forget you have approx. ONE HOUR to try something else - if at the end of that time you're still having a problem, contact a moderator.
PPS. If you need help with resizing images etc, then PM a moderator with details of the image manipulation program you're using (if you have one) and they’ll get back to you a.s.a.p. Note: there are free programs you can use in the ‘Posting Images – Maximum Sizes etc’ sticky.
