Results 1 to 6 of 6
Thread: Should I keep?
    Senior Member Steve52's Avatar
    Apr 2007
    Dawlish, Devon, UK
    Should I keep?
    When doing my band work, I take Minolta F2.8 28mm, Minolta F1.7 50mm and a Sigma F2.8 70-200 lens.
    I have just ordered a Sigma F2.8 24-70mm lens.
    Is there any advantage in keeping the F2.8 28mm, as the new lens covers this?
    FRIPN. Never argue with an idiot. They'll drag you down to their level, then beat you with experience.
    www.flickr.com/photos/mrsony/
    Senior Member frank1's Avatar
    Jun 2005
    the big smoke islington
    Re: Should I keep?
    Prime lenese are are better than zooms, I'd say hold on and compare.
    With as stony a stare as ever Lord Reith could have conjured up... TimF's Avatar
    Jul 2001
    Herts/Beds border
    Re: Should I keep?
    That depends on the relative age of prime and zoom. Some modern zooms are as good, if not better, than some older prime lenses.
    That said, I'd still agree you should keep it, if only for those occasions when you want the focal length, but don't wish to cart a heavy zoom lens about.
    Tim BSRIPN
    Ethelred the Ill-Named
    Sep 2006
    Nottingham
    Re: Should I keep?
    I would modify that statement. "I'd say hold on and compare. Then make your own mind up.
    Prime lenses used to be better than zooms. You are going to compare an old, but respected prime to a modern fast zoom.
    Please let us know your findings.
    Apr 2007
    Dawlish, Devon, UK
    Re: Should I keep?
    I'll be photographing a band in a couple of weeks. I'll try and take similar pics using both lens, though with the light show bands use nowadays, might be difficult.
    Senior Member El_Sid's Avatar
    Apr 2003
    Sussex-by-the-Sea
    Re: Should I keep?
    WHS
    I have the 28-70mm version of the lens you are buying and it can get to be a bit of a millstone round the neck after a while...
    Completely BSRIPN
    The New El Sid Gallery or
    The El Sid Gallery 2
