Chaps, forgive me for being thick...but I'm going to ask this anyway...
Seeing as how Elements 6 does not have "Layer Mask", am I correct in thinking that the same result can be achieved simply by erasing the background/bits you don't want to change using the "Eraser" tool in the "Teeth" layer (to use Richard's example)?
Is the only difference that if you make a mistake using this method, it basically means you're screwed and have to start again...as opposed to being able to "paint white" over your mistake (as it says in the article)?
Sorry...not very good with PS...but want to make an effort to learn this stuff!
