Results 1 to 4 of 4
Thread: Elements 6 Photomerge
    Feb 2007
    Edinburgh
    I'm a bit miffed, every time I try to make a new photomerge panorama it crashes Elements. Has anyone else encountered a similar issue?
    I haven't done any panoramas for ages, so thought I'd try it out seeing as PSE6 is apparently very good for this. Quite disappointed that it doesn't work at all.
    Aug 2006
    North Surrey
    Re: Elements 6 Photomerge
    I've done panoramas in E6 with no problems using three separate files. They were all hand held so took a little 'cleaning' afterwards but E6 made a pretty good go of the initial merge.
    Feb 2007
    Left hand down a bit..
    have you enough memory.....photomerge loves RAM...I have 1gig and in PSE4 there are times when it coughs and splutters through the process....
    David
    We are here to learn.
    Feb 2007
    Edinburgh
    Sorry for not saying anything in response to you guys, but I still haven't had a chance to play around and try with smaller files (although 6MP jpgs shouldn't really create issues) in case it is memory related. I'll keep you informed.
