Results 1 to 9 of 9
Thread: MF condenser & lens or Gnome enlarger
    Senior Member gray1720's Avatar
    Jan 2009
    Oxford
    I've been considering developing my own for a while now as my box camera collection has largely stood idle since I lost the use of a darkroom - it's not the same when you have to spend a tenner for eight shots, all of which may be crummy!
    Anyway, I've just picked up for next-to-nothing a Gnome Universal Alpha II enlarger. Not the best bit of kit around, but cheap and convenient to collect. It has a 35mm condenser in it and a 50mm lens. I'm told that you can just about get an 8x10 print from a 6x9 neg with that set up, by someone who used to use one, but I'd really like the proper bits for medium format. Does anyone out there happen to have a longer lens and condenser hanging about, before I try to buy one, or try to use as a diffusion enlarger?
    Thanks,
    Adrian
    All part of the fun of extreme vintage photography
    You'll be amazed at the carp I've posted here: http://www.flickr.com/photos/gray1720/
    Not Really Here
    Aug 2000
    Re: MF condenser & lens or Gnome enlarger
    It has a 35mm condenser in it and a 50mm lens. I'm told that you can just about get an 8x10 print from a 6x9 neg with that set up, by someone who used to use one...
    Sounds like hogwash to me - I don't think any 50mm enlarging lens ever made has had a wide enough field to cover 6x9 at that magnification, and if it had I hate to think what the corner quality (not to mention light fall-off) would be like. And how a condenser set designed for 35mm would cover 6x9 is equally baffling.
    Jan 2009
    Oxford
    Well, if that is the case then it increases my need for the right bits, doesn't it?
    "Hogwash" is a word that should be used more often. And I like your BS meter spotted elsewhere.
    Adrian
    Not Really Here
    Aug 2000
    Thank you!
    Jul 2005
    Milton Keynes, UK
    You could try S/H Darkroom Supplies, Nova Darkroom and MXV darkroom page.
    I expect you'll have to ask for things like condensor lenses.
    I bought my Gnome Alpha some years ago, used it once or twice, but have never thought of getting rid of it.
    Malcolm Stewart
    Jaguar Mk VII
    Member
    Sep 2006
    North Yorks
    I don't know your particular enlarger model but Gnome made quite a number that were very similar and some of the parts were interchangeable. However as a guide for a 2.25 x 3.25 negative you will need a 105mm (41/4") condenser - is your enlarger big enough to take one? Also your lens will need to be about 100mm to 105mm in focal length to cover the whole negative.
    lenses should not be a problem but I can imagine the correct condenser pair (Yes you need 2) will be somewhat of a challenge plus the necessary housing to hold them in place. I wish you luck but I would not hold my breath.
    Jan 2009
    Oxford
    Hi John,
    Thanks for the advice. Yes, there's plenty of space in there - you could fit a fairly hefty condenser in there. Think 1950s hairdresser's hairdryer! I've not measured the internal diameter of the housing, but it's at least 4 1/4".
    So the condensor lenses need to be the same diameter as the focal length of the lens... As you say, I've seen several lenses (I have a possible source...), but not condensers. There are two lenses on ebay at the moment, no housing with them, but they are 3 1/4" so presumably would be for a 80mm lens? And for 6x6 or 127, presumably?
    Frankly, I'm a tinkerer, so if I can't do MF I shall just do 35mm, and keep my eyes open.
    Adrian
    Member
    Sep 2006
    North Yorks
    Another possible source for 4.25" condensers could be Mr cad in Crodon:-
    www.mrcad.co.uk
    or if you Google 'Gnome Enlargers' there are a few sites that support that topic.
    Have fun.
  9. #9
    Jan 2009
    Oxford
    Thank you gentlemen - a friend has now offered me a Gamer enlarger (wish he'd told me earlier!), so I may end up with two - will see whether this one has a MF condensor or not (he used to shoot a Rollei, so I might be in luck....). If not, I have lots of options, and I've just had a nice chat with the guy from second hand darkroom, who is only a few miles down the road.
    Most annoying thing so far is discovering that Nova's portable darkroom is 10cm taller than our bathroom ceiling - renting a flat, there's only so much you can do to make it dark!
    Never mind - a bit of cunning will find a way, just have to find a bit of cunning...
    Adrian
