Results 1 to 5 of 5
Thread: Whats going wrong??
    Junior Member
    Oct 2008
    Whats going wrong??
    Hi,
    Having just bought my first decent digital camera, a Fuji S100FS, I'm a little disapointed with the results.
    When viewed 'actual size' on my pc they appear very grainy as though shot at very high ISO although I've used 200 during daylight outdoors.
    I've also noticed that straight diagonal edges appear zigzagged when I've reduced the image size on the pc.
    Before buying the s100fs I researched it fully and none of the review shots showed any of the problems i'm experiencing.
    Is it me or the camera at fault? I hope its me!! Any advice will be appreciated in helping combat the above
    Mar 2002
    London'ish
    Re: Whats going wrong??
    A few quick questions to help us in answering your questions...
    What quality settings are you using on the camera?
    What software (and process) are you using to resize the photos?
    Margaret Atwood
    Senior Member AGW's Avatar
    Oct 2003
    Ayrshire
    Sounds like its set to the smallest jpeg?
    AGW (BSRIPN)
    Blessed are they who see beautiful things in humble places where others see nothing. (Camille Pissarro)
    Junior Member
    Oct 2008
    Hi,
    I've put the noise down to out focus due to depth of field.
    The zigzagging has gone now that i have used an old edition of photoshop elements.
    Can you recommend any free software which would give better results than elements 2.0?
    Camera was set to 10M Fine
    Many Thanks
    Member
    Dec 2006
    If you are viewing your image at 33% or 67% of its size, it will introduce jagged edges/contours.
    Try viewing you image at either (in %) 12.5, 25, 50, 100.
    As for the noise, it may be caused by underexposure at the time of capture. If you tried to up the exposure (or adjusted curve upwards) in post-processing to compensate, it will introduce noise.
    HIH
    Benji
    (photoshop elements is more than fine for opening/viewing your pics, but try and stick to the % indicated above when assessing your work)
