Results 1 to 4 of 4
Thread: Infra red filters
    Sep 2006
    North Yorks
    Infra red filters
    I don't mean the Wratten 25 deep red, but the opaque filter version. I bought a SFX kit which came with a gelatine I/red opaque filter in a mount that fitted the Cokin 'P' holder. It works well too with my 28/105 Nikkor. However the gelatine filter is held in a sub mount which gives extreme vignetting when I use it with my 17/35 Nikkor Is there anyone who produces a 'P' size IR opaque filter that slides into a cokin mount with no sub mount
    Jul 2007
    Really Here In Name Only
    Re: Infra red filters
    I suspect you may be better off looking for a filter that screws directly into the filter thread on your lens. They're not cheap. For SFX you probably want the B+W 092 rather than the 093 which may not pass enough "short" infra red to activate the film.
    Sep 2006
    North Yorks
    No there is no vignetting with a normal 'P' series Cokin and I use these regularly I was just trying to find out if anyone made one with the opaque I/R filter. The one that came with the SFX, the overall mount is the same as a cokin filter, but the actual gelatime filter part itself, is in a circular aperture only appox 60mm in diameter. Not even as big as the FRONT element of the 17/35
    Apr 2006
    Devon, UK.
    Just measured the aperture of my SFX filter for Cokin P and it's 75mm across. Not quite big enough for the blu-tak, although you might get away with it.
    MATWSIJ.....
