Results 1 to 8 of 8
Thread: How good is universal Print and film Developer?
    Senior Member Bone_Idle's Avatar
    Jul 2006
    Bradford
    A quick question. How good is universal Print and film Developer?
    I'm wanting to try home processing and printing and have managed to cobble together a few items from eBay and freeCycle, and not I think I just need to get some chemicals.
    I like the idea of a universal developer as it cuts down on expenditure whilst I experiment.
    The Developer in question is Champion Suprol Universal Film & Print Developer, and I'll also get the Champion fixer.
    Nick
    Technical Writer
    Aug 2007
    Re: How good is universal Print and film Developer?
    For experimenting universal developer should be fine. As you progress you may want to read up on a few different developers for films/paper that produce slightly different results.
    From experience I've found that universal developer tends to produce better results for paper than it does for film.
    Marvin beejaybee's Avatar
    Jul 2007
    Really Here In Name Only
    Which one?
    I used to use ID-11 for both film & paper. Worked very well for both, but that was before multigrade.
    Jul 2006
    Bradford
    It's Champion Suprol Universal Film & Print Developer - saw it at First call photography.
    Nick
    Jul 2006
    Bradford
    Nick
    Member taxor's Avatar
    Jul 2004
    Lancaster, NW England
    As per the other replies. For experimentation, no probs. For anything approaching a fine print, use a dedicated film dev.
    Can't be a***d with a signature.
    Jul 2006
    Bradford
    I suppose the next question is, what is a recomended film developer?
    Bear in mind I have not developed a film before, so I don't want anything that needs 100% precision regarding temperature and mix etc.
    Nick
    Senior Member Terrywoodenpic's Avatar
    Jan 2006
    Saddleworth UK
    Most universal developer work well for prints but less well for film.
    If they give a range of dilutions and development times, use the greatest dilution they state. it will give the best shadow detail and least grain.
    Don't add any time or temperature for "luck" you will just increase contrast and grain.
    65 happy photo years from amateur to professional and back. Caught the bug Young.
