Results 1 to 20 of 20
Thread: Dedicated black and white digital camera?
    Junior Member doctorbeat's Avatar
    Feb 2008
    I'm wondering about the feasibility of converting a digital compact to shoot just black and white.
    It seems to me that there would be several advantages to a dedicated B&W digital camera.
    It seems from what I have read on the subject that colour digital sensors need a bayer filter and a moire filter, and then the image needs unsharp masking to correct the effects of the filters.
    If a camera had just the sensor (and maybe an IR filter) then the images should be of better quality, and the camera would be able to operate at the equivalent of much lower iso ratings (ie less noise)
    I have recently bought a new samsung NV10 as a daily carry camera. (I did want the NV7, but I got an offer I couldn't refuse on the NV10, plus it's easier to slip into a pocket)
    That means that my old compact (a Rollei badged thing) is now redundant.
    I have already converted an old compact to a dedicated IR camera with fantastic results, and I still regret giving it away....
    I wonder if it is possible to remove the bayer filter and the moire filter from the CCD of my spare camera to achieve my goal of a 'proper' B&W camera?
    Has anyone heard of this being done, or have any ideas/ information that may help me?
    I'd be more than happy to contribute a series of photos of the process to the forum if I manage to get this working.
    Marvin beejaybee's Avatar
    Jul 2007
    Really Here In Name Only
    Re: Dedicated black and white digital camera?
    Is it really necessary to remove the Bayer filter? Can you not just sum the outputs in the ratio R:G:B = 1:2:1?
    I rather think that you would need to tinker with the software as well as the hardware to get the full benefit of removing the Bayer filters - if that can even be done; are the filters an integral part of the microlenses, or is there a filter layer between the microlenses and the sensor substrate, in which case removing or substituting it would have to be done very carefully to avoid upsetting the alignment of the microlens array with respect to the sensor sites, which is critical to the efficiency of the system.
    There are lots of different monochrome CCD/CMOS sensors available, if you want to start from scratch; which may possibly be a better place to start from, if you want to realise the higher quantum efficiency of a monochrome sensor.
    But, if you just want lower noise, perhaps colour to monochrome conversion starting from a sensor with bigger photosites (i.e. a DSLR) would be the most economic approach.
    In any case I don't see what possible benefit there would be in removing the moire (anti-alias) filter, unless you have some alternative method of processing out aliasing artifacts.
    Feb 2008
    You're probably right about the software side of things.The impression I got from what I've read (and I haven't found much) is that the microlenses might not be necessary in a bayerless B&W sensor (but I have no idea if this is true), and that the moire filter is there to correct the effects of the bayer, so should also be unnecessary.
    I'm not really interested in doing this for fantastic image quality, just more of an experiment to see if it can be done. The idea that the bayer filter 'gets in the way' and has to have its effects corrected also intrigues me, and it would be interesting if I was able to turn my crappy point and shoot into a very high resolution camera capable of producing good images in very low light situations.
    I know it's better to shoot colour and then convert to B&W than use a camera's inbuilt B&W setting, but wouldn't it be nice to have a digital camera that behaved like a 'real' camera loaded with B&W film? You'd be able to use filters too.
    I know I could just use a film camera, but I'm afraid I've become a bit of a digital addict. Although I do enjoy the developing process, I just can't argue with the convenience of digital.
    I'd be the first to admit that I'm not a very accomplished photographer, and the throwaway nature of digital has in my case improved my photography simply due to the law of averages!
    I do have a DSLR, but I've found that I tend to leave it at home. That's why I bought the Rollei- it's my constant companion, and I guess the first rule of photograpy is to make sure you have a camera!
    After my experiment of carrying a compact constantly, I found that I was actually taking some photos for a change so I decided to get a nicer model.
    I wanted the samsung NV7, but I got a really good deal on an NV10.
    Personally I think 10Mp is too high for a compact, and I'm a little worried about the noise generated by fitting so many pixels on a compact's sensor, but as you rightly point out, I have my DSLR if I need better quality.
    I guess I'm just pining for the days of old with rangefinders, tlr's and B&W film, but now I have been spoiled by digital so I want the best of both worlds.
    I think my Ideal cameras would be a digital B&W only Leica rangefinder, and a digital TLR.
    Nowadays it seems that compacts are losing their viewfinders too, which is a real shame.
    One distinct advantage of a dedicated B&W compact would be that the LCD would also display in B&W, which I think would help with composition.
    Jul 2007
    My understanding is that the microlens array is necessary in order to obtain a reasonable quantum efficiency. Without it, a very large proportion of the incident light would hit a portion of the sensor chip which was not sensitive to anything.
    Some sensors also use the microlens array in a clever way - the microlenses towards the edges of the sensor are bigger and/or angled so as to reduce the effect of vignetting.
    The moire pattern in the individual RGB channels is indeed twice the size that it is in the summed output, but nevertheless aliasing ("steppiness" of an angled line) is an inherent feature of all sensors which use regular tilings of photosites. I quite agree that the necessary filtering could be done in software on the PC after downloading the image from the camera, if you can get hold of the raw data - if the camera software has processed the sensor output by a lossy algorithm (e.g. JPEG output) then the opportunity is gone.
    Sure. But - fiddling around with my Canon 5D and a bunch of "monochrome" filters screwed into the threads at the front end of the lens- it looks like you can use the filters quite effectively even with the monochrome conversion built into the camera. Deep red does not work as well as it should do - the IR blocking filter is actually removing some of the visible red as well - anyone who has tried taking photographs of nebulae which shine by hydrogen alpha emission (656.28 nm) will be aware of the weak response of the sensor in most digital cameras. As you've already found, removing the IR blocking filter isn't too hard - they're actually intended to be replaceable, with filters with different transmission characteristics available for different specialist applications - but the microlens array & coloured filters used by the Bayer matrix are much more intimately linked with the sensor substrate.
    It is of course necessary to disable the camera auto white balance when using coloured filters - on the 5D just set white balance to "daylight" - actually mine is set that way all the time, I do any necessary white balance correction in the raw converter software after downloading the images.
    Absolutely. Incidentally I usually carry an old manual compact film camera (Rollei B35, usually loaded with HP5+) even when I am carrying my Canon 5D, and certainly when I leave it at home.
    Absolutely agree. I find it very hard to compose on a screen held at arm's length, and even harder to keep the horizon level when shooting that way. Having to carry a tripod - and a black cloth to keep sunlight off the LCD screen - seems to negate the only real advantage a compact camera has - portability!
    I don't find any particular problem with composing in monochrome - what I do have a problem with is visualizing what the effect of the conversion to monochrome will be, especially when not using a deep red filter! I find looking around me (not necessarily through the camera viewfinder) with a green filter held to the eye helps ... perhaps observing a colour LCD through a filter similar in colour to the effect you want would help.
    Feb 2008
    Thanks for your replies, and yes, it seems like my idea wasn't as straightforward as I thought!
    Never mind....
    When I said that a B&W viewfinder would make composition easier, I was in error really. What I meant was what you say about visualisation of the image in mono. I'm better at it than I used to be, but for a rank amateur like me, the less guesswork I have to do the better, and a B&W viewfinder would be a godsend.
    I do sometimes pop my camera into B&W mode just to have a look before I shoot in colour, but my DSLR (Nikon D50) doesn't have a B&W setting, so I can only do this on my compact.
    The main thing I hate about not having a viewfinder is the lack of stability. I try to avoid using the flash on my compact as much as possible, but holding the thing at arm's length is not very stable, plus one point of contact (the face pressed to the camera) is absent.
    This means that I often have to use flash if there isn't much light, as a slower shutter speed would make a blurry image, so the lack of an optical viewfinder really does have a large impact on the quality of my pictures.
    This was one of the reasons I was hoping to make this B&W conversion. The impression I got was that the sensor would be far more sensitive, and therefore I would be able to take more shots without resorting to the on- camera flash.
    I suppose you could liken the lcd screen to the viewfinder on a TLR, but TLR's can be braced against the chest or some other body part, while this isn't really practical with a digital compact.
    I was very surprised when Leica came out with their rebadged Panasonic cameras with no optical viewfinder- what's the world coming to?!
    Senior Member zx9's Avatar
    Jun 2007
    London
    I have found that by holding the G9 and tensioning the neck strap, pushing the camera away from myself I can hand hold at very low shutter speeds. It had occured to me that it is a stance not unlike steadying a TLR by pulling down on the neck strap.
    Regards,
    Keith Hudson - ZX9
    Feb 2008
    Yes indeed, I do the same thing with the wrist strap on my compact.
    Now you mention it, that's another thing that's gone south that I miss- neck straps instead of wrist straps.
    I know cameras have got smaller, but a neck strap with two anchor points on the camera is a really good aid to holding the thing still.
    I'm not old enough to really remember when rangefinders were in their heyday, but when I was a kid I had your usual compact camera.
    I remember asking my dad why some of my photos had turned out so bad, and he explained to me about cameras that required more thought and input from the photographer (ie manual settings) that were harder to use but would give better pictures if used correctly.
    At the time, an SLR was not a camera one could buy for a child as they were pretty expensive, but he did get me a Voightlander Vitoret, which I still have.
    This was the camera that got me hooked on photography, and is also the type of camera that I miss.
    It seems that features that were on the cheapest cameras back then are now only available for enormous prices in the new digital age.
    I don't want to spend loads of money on a Leica or the Epson rangefinder because I use my compact to go places I wouldn't take my SLR.
    I have a cheap compact precisely because I won't cry if I lose it!
    It's just a shame that you don't seem to be able to get a low priced compact with a two point neck strap, an optical viewfinder and maybe (dare I ask?) an eveready case. None of these features are expensive to produce, they just aren't fashionable.
    Aug 2000
    Everywhere and nowhere, baby
    Thank goodness as regards the never-ready case!
    I've got several digital compacts (none of them all that new) and only one - the smallest - doesn't have an optical viewfinder. That one is very small, fits nicely into a pocket and I certainly wouldn't want a neck strap for it. In fact only the oldest one I own is big enough for a neck strap (it's a similar size and weight to a Vitoret) - and it actually has one. The others are pocketable, and that suits me much more than a case or a neck strap.
    Maybe, but the converse is also true - even my absolute basic pocket camera has a choice of metering modes, for example.
  9. #9
    Senior Member Mojo_66's Avatar
    May 2006
    Lancs
    The Sigma SD14 has a Foveon sensor, doesn't tend to suffer from moire and so doesn't have an AA filter. It does have an IR filter for normal use, but this is removable if you want to shoot IR, which apparently is easily possible to do hand held, I haven't tried it with mine yet though. Images from it printed to A4 look very smooth up to ISO400, much smoother than I get with film, as long as you don't underexpose, then you start getting some green blobs in there, with mono though you wouldn't notice this. The same sensor has just become available in the Sigma DP1 compact.
  10. #10
    Member Rhys_Hardwick's Avatar
    Apr 2007
    Cardiff, Wales, UK
    I have skim read the above, and sorry if someone has already said this. The huge advantage of removing the bayer array and having a luminosity-only sensor is that you can gather much more light. If you take R G and B filters as reducing light from 2-3 stops, you can effectively gather 2-3 stops more light, therefore increasing the effective sensitivity of the sensor.
    Furthermore, each photosite can be mapped to one pixel, increasing pixel count by 4-fold.
    These are the main advantages I can see.
  11. #11
    Jul 2007
    True, but I rather suspect 2-3 stops is a gross overestimate of the loss. Nevertheless for the highest quantum efficiency astronomers use monochrome sensors - making seperate exposures with R G & B filters when necessary for colour work.
    Not so, the pixel count is fixed ... the trick is that, with a Bayer filtered sensor, the "missing" intermediate pixel values (75% of them for the R & B channels, 50% for the G channel) are interpolated from the data which is available.
  12. #12
    Feb 2008
    Yep, that was what made me want to do this.
    It would like having a super fast lens and a higher pixel count with less 'wizardry' necessary to correct the image afterwards.
    Benchista, I take your points about the eveready case and the neck strap, but i would still love these features on a tiny pocketable camera.
    My compact has a shutter that closes when the lens is retracted to protect it, but it is really flimsy and lets pocket dust in. I would much prefer a case that could be deployed as fast as an eveready type, I just hate those velcro- flapped 'purses'.
    I would like two attachment points to allow a neck strap to be used because as well as being a good brace, sometimes it's nice to just let go of the camera and let it drop to my chest. It's then ready for the next time I want to use it.
    The neck strap could be as thin as the wrist strap, I didn't mean a big wide one like on SLR's.
    I suppose there's no reason why I couldn't use a neck lanyard that attaches at one point only...
  13. #13
    Jul 2007
    OK, you would need a big pocket, but in the current AP there is an advertiser offering an ever-ready type case for the Canon G9!
  14. #14
    Member tazio35's Avatar
    Oct 2007
    Cromer, Norfolk
    I used the thin neck strap that came with my Holga on my Minolta Hi-Matic F. I tried using both attachment points, but the camera tended to flip over and was uncomfortable. I then clipped both ends of the strap to one point and it made a huge difference.
  15. #15
    Senior Member AJUK's Avatar
    Mar 2005
    UK
    I think a Dedicated B&W DSLR would be more worth while.
    Al
    [Insert clever comment here]
  16. #16
    Junior Member
    Nov 2006
    unfortunatley you could only use it in jpeg mode As to seeing in black&white I think that RGB company does a device that you can place in front of your eye and you see the world in black&white
  17. #17
    Mar 2002
    London'ish
    Who are "RGB company" ?
    Margaret Atwood
  18. #18
    Aug 2000
    I suspect it's SRB...
  19. #19
    Senior Member Burgy's Avatar
    Apr 2001
    An Inch From....
    You could always see if you could find a used Kodak DCS1m
    Kodak EOS-DCS 1m (Monochrome, 6 megapixel, based on Canon EOS-1n)
    From memory it is limited to 200ISO, and the technology is a little old
    Cheers
    Burgy BSRIPN, BSc, DSO and Bar (now open 24/7).
    it's not what you've got, its who you do it to
    http://togsblog.wordpress.com
  20. #20
    Feb 2008
    Ok, this is an old thread of mine, but I'm resurrecting it because, not only do I still want to do this, but also because other people actually have.
    I've found just enough information about this to be tantalizing, but not enough to actually carry out a successful conversion yet:
    http://photo.net/casual-conversations-forum/00RmUd
    (search for posts by Joseph Wisniewski)
    and:
    http://photo.net/digital-camera-forum/00CM0R
    So, it seems that this can and has been done successfully!
    Using the information in the second link, I attempted to convert my old compact, but unfortunately had the same accident that the guy had a couple of times. Even though I was extremely careful, I broke one of the tiny wires on the CCD.
    Sadly, this seemed to upset the camera so much that it no longer boots up properly, so I can't see what difference my CCD scraping made to the image.
    The uppermost link that I posted mentioned the use of solvents, and I think this is the way to go because the wires are so small and delicate that even brushing one with a Q-tip is enough to dislodge it.
    Before I had the accident, I had tried filling the CCD with pure acetone, but it seemed to have no effect. Only scraping with a razor blade removed the filter.
    Ironically, the blade wasn't what caused the damage, it was while cleaning away the scrapings with an acetone soaked Q-tip that I nudged the wire and broke it.
    I guess I should have been more patient before resorting to scraping with a blade, but the acetone evaporated so quickly that it wasn't really possible to leave it to soak for any length of time.
    So, I still don't know if acetone alone would do the job if left long enough, but I do know that someone has used aliphatic solvents to remove a bayer filter.
    I originally just intended to do an IR conversion on the camera, but once I had the CCD exposed, I couldn't resist having a go at bayer removal.
    have just bought another cheap compact on ebay (Kodak V1003 for $15) to replace my broken one and do the IR conversion on it, but I'm still longing for a bayerless camera...
    I'll try acetone for a longer soak on this one, as this doesn't involve touching the sensor. If it doesn't work, I won't risk any scraping and just go ahead with a simple IR conversion.
    Before I do this though, I have one concern.
    The camera has no RAW mode, only jpeg.
    If I successfully remove the bayer filter, will I end up with a useful B&W image (after desaturation of course) or will the confused software give me a load of nonsense?
    I've read so much conflicting information and speculation on this that I don't know whether it's even possible to do what I want to do to a camera that doesn't have a RAW mode.
    Can anyone give me a definitive answer?
