Results 1 to 12 of 12
Thread: CS2 vs CS3
    Senior Member Lounge Lizard's Avatar
    Jan 2004
    Cambridge, Cambridgeshire
    CS2 vs CS3
    Does anybody find CS3 to be noticeably slower than CS2? Maybe it needs a bit more memory but it seems so sluggish compared with CS2 running on the ame machine.
    <font color="#004d83">Lounge Lizard
    Winston Churchill
    Oct 2005
    Gloucester, UK
    Re: CS2 vs CS3
    I have not noticed any speed drop with CS3 - if anything it seems a bit faster. I have just an average PC with P4 3.2 GHz and 2048 MB RAM. CS3 program and its scratch disk of different hard drives.
    Hinkypuff ermintrude's Avatar
    Jun 2003
    London, UK
    Re: CS2 vs CS3
    I havent tried CS3 but moving from CS to CS2 was insanely slower...I still really hate opening/closing PS, it just takes eons...
    (Ctrl A > Ctrl C )
    ..or eight Seven's Avatar
    Feb 2003
    Havant, UK
    Re: CS2 vs CS3
    You definately need 1gb of memory and a fast machine to cope.
    I had CS3 on my old PC and it was unbelievably slow at shutting down.
    With an intel core CPU and the extra RAM it's as quick as CS was
    Tanya(BSRIPN)
    CastVision
    Photoportal
    Oct 2005
    Gloucester, UK
    Re: CS2 vs CS3
    I've just timed CS3 on my computer (which is nothing special - see above). Opening 4 seconds, closing 1 second. This is when it's been open previously the same day. I guess it must leave something in memory even after it's closed. It takes 10 seconds to open the first time each day.
    Feb 2003
    Havant, UK
    Re: CS2 vs CS3
    Crikey you are going to have me timing mine now shall get back to you on that one
    Tanya(BSRIPN)
    CastVision
    Photoportal
    Member radiogandy's Avatar
    Dec 2006
    Nottinghamshire UK
    Re: CS2 vs CS3
    Can't afford CS3 at the moment. So I run CS2, and also Elements 4. I know it sounds a bit daft but Elements 4 is good enough for 90% of my projects and it is much much quicker. I can nearly 'open with', do the job, 'save as' and shut down while CS2 would still be loading !
    Slight exaggeration but only slight.
    ..Kurt Vonnegut....."<u>Those who believe in telekinetics, raise my hand</u>"
    Radiogandy's Blog
    Apr 2003
    Just West of Norwich, Norfolk
    Re: CS2 vs CS3
    I hear from members in our club that CS3 is much better at RAW conversion. I am still a bit reluctant to spend the pennies, but I know I will eventually succumb. I have a DELL with AMD Athlon X64 dual processor and 2 gbytes of RAM and CS3 runs very well. I do not expect CS3 to be any slower, at least I hope not.
    David.
    Photos hosted by Flickr.
  9. #9
    Member Meredith's Avatar
    Oct 2006
    Coventry, UK
    Re: CS2 vs CS3
    I haven't found CS3 to be slower than CS2 on my system.
  10. #10
    Technical Writer
    Aug 2007
    Re: CS2 vs CS3
    If you are using it primarily for raw conversion, look at Adobe Lightroom - it's a lot cheaper than Photoshop and I find myself using it for the majority of my editing.
    I haven't noticed a huge difference between CS2 and CS3 in terms of speed.
  11. #11
    Apr 2003
    Re: CS2 vs CS3
    I have CS2 already, is Lightroom cheaper than the CS3 upgrade? Upgrades to Photoshop seem valid for at least two editions, so I could skip CS3 this time, if the RAW converter in Lightroom is the same as CS3. This might be a cheaper option. Convert RAW in Lightroom to a tif, then use CS2 for enhancement.
    Your advice would be most welcome here, thanks.
    David.
  12. #12
    Senior Member Benchmark's Avatar
    Jul 2005
    Sedgefield, Co Durham
    Re: CS2 vs CS3
    I still have CS2 on one of our desktop machines (Compaq Deskpro with 2.8 GHz Pentium 4, 1.5 GB RAM and 250 GB Maxtor HDD).
    Time taken to load CS2 was 8 seconds (first time) and around 7 seconds when re-opening.
    The time taken to load CS3 on a second identical machine was 13 seconds (first time) and 5 seconds when re-opening.
    I also use CS3 on my Toshiba Tecra laptop (Pentium M 1.8 1 GB RAM).
    The time taken to load CS3 was 22 seconds (first time) and just 3 seconds when re-opening. (I tried this a few times, as I was surprised how quickly it re-loaded).
    In all cases, CS3 shut down instantly provided no files were open.
    From the above, it will be seen that CS3 takes a little longer to load first time, but actually re-loads faster in the same Windows session (provided the memory blocks have not been re-written). Once open, CS3 seems to run just as quickly as CS2, but adjusting very large files (scanned from medium format) does require a little patience.
    I find the RAW converter in CS3 much more competent than CS2 (especially the ability to adjust sharpening, fill light, etc), but in other respects I don’t see much difference between the two.
    Nigel CRIPN and Bar
    Beware of the Dark Slide
