Results 1 to 3 of 3
Thread: My old Zeiss lens on an EOS body
    Senior Member zx9's Avatar
    Jun 2007
    London
    I could have posted this in the Canon forum but as it may be of interest to users of other systems and as the Contax Yashica forum is looking a bit sad, here goes.
    Having used two Contax cameras a RTS and 137MA for over twenty years, the 137MA started to let me down earlier this year. It now leaks light and the frame spacing is not good, to the extent of overlapping some images.
    I have always had a liking for Canon and want a 5D eventually but not at £1100 for a rough used example, so off I went and bought a rough used EOS5 (film) to start building a new system around.
    I have a couple of lenses 28-70 F2.8 and an 80-200 F2.8, both old but good, providing you use the lens hood on the 28-70.
    What I want to do is use my Zeiss 85mm F1.4 on the EOS, yes it will be manual focus and aperture but as I often use it wide open there will not be a lot of stopping down to taking aperture.
    My question is do I buy an adapter with the chip to allow focus confirmation or one without. What do you use and indeed do the 'chipped' adapters work satisfactorily ?
    Thank you in anticipation.
    Regards
    ZX9 (Keith)
    Regards,
    Keith Hudson - ZX9
    Aug 2000
    Everywhere and nowhere, baby
    Re: My old Zeiss lens on an EOS body
    I have an unchipped adaptor (the Cameraquest one). I use the 85P on my 5D, and also used it on the 5 when I first got the adaptor. I have no real problems focusing it with reasonably static subjects with either the original 5D screen or the gridded one, but it's not always so easy with moving subjects. However, this lens is the Zeiss one that I use most frequently on the 5D - although at the moment, it's back on my 137MA for old times' sake.
    Member Per's Avatar
    Nov 2005
    UK Berkshire
    Same here - I've used a CameraQuest one with 85 f/2.8 and 50 f/1.4 CY Zeiss lenses on my EOS1v. It works exactly as advertised and the engineering is good if expensive.
    The website is here
    There are two things to aim at in life: first, to get what you want; and after
    that, to enjoy it. Only the wisest of mankind achieve the second.
    Logan Pearsall Smith (1865-1946)
