Results 1 to 10 of 10
Thread: Query re polarising filters
    Oct 2006
    North Cumbria
    I took a photograph at the weekend of sky, hills and trees reflected in a lake.
    The reflection of the sky had better colour saturation than the real sky.
    My question is; would a polarising filter have given better colour saturation to the sky and could this have adversely affected the reflection in the lake?
    Thanks in advance
    Dave
    Jul 2004
    Lancaster, NW England
    Re: Query re polarising filters
    Dave,
    Using a polariser might have enhanced the sky. It really depends on where the sun is. Maximum polarisation is usually at right angles to the direction of the sun. Also, polarisers are used for eliminating unwanted reflection and glare, so you may well destroy the reflection in the lake. A better solution might be to use an ND (neutral density) grad filter to darken the sky, thus retaining the saturation of the foreground.
    Can't be a***d with a signature.
    Oct 2006
    North Cumbria
    Thanks for that. Are ND filters ever screw-in or are they always the 'Cokin' type?
    Dave
    Mar 2002
    London'ish
    Problem with screw-in NDs is that the grad is always in the same place.
    Much better to go for the Cokin types
    Fen .......... My Website and Blog - My Flickr - My InstaGrams
    Margaret Atwood
    Jul 2004
    Seconded!
    Apr 2007
    Cherry&Whites
    funny, only recently I asked a nikon rep on an after-sales board about the cokins for my D40X for the same reason as here, keeping foreground and enhancing sky. What I'm still not sure about even though this is supposedly from a nikon 'rep' he suggested the A series, yet I've read somewhere that the P series is better for AF-S type lens/cams. So I'm still undecided unless someone here can explain why the one is better suited than the other.
    Aug 2000
    Everywhere and nowhere, baby
    The A series is suitable for lenses with smaller filter threads, the P series for larger ones. If in doubt, P makes more sense - but is a little dearer.
    Sep 2006
    Ayia Anna, Hub of the Universe
    I have just recently had to supplement my P series with an A series for my standard (50mm) lens, because the area of gradation on the P series was too large for a small lens. I couldn't find a suitable adapter to move the P mount far enough away from the lens to be useable. This is worth bearing in mind when buying a Cokin mount.
  9. #9
    Aug 2006
    Brecon, South Wales, UK
    If you can't get the effect you want using a polarising filter, then I will take a couple of shots under and over exposing and merge then together in photoshop.
  10. #10
    Oct 2006
    North Cumbria
    Thanks to everyone who took the trouble to reply.
    Dave
