Equipment >> Lens Matters
attack_donut
enthusiast
Reged: 16/12/2006
Loc: East Coast
Push-pull or twist-zoom, is one better?
      #804951 - 25/06/2009 21:44
I have a Nikkor 35-70 push-pull 'zoom' lens, which I like very much. I know it's good quality and sharp.
I have some that are twist to zoom which are also good.
Just curious, is one design superiour to the other, or is it simply a matter of cost-to-produce?
Cheers!
AD
So rise up, o ye lost ones
As one we will claw the clouds
Rise up, the forsaken and dethroned
A legion wronged, to claw the clouds
mediaman
Nearly Laid Back
Reged: 28/07/2008
Loc: edinburgh
Re: Push-pull or twist-zoom, is one better? [Re: attack_donut]
      #804955 - 25/06/2009 21:57
Some "push/pull" types,if "weighty" can creep from one focal lenth to another, while the camera is still hanging around your neck.
The more a lens is used, the more chance of this type of "zoomcreep"
Optically, I don't think either lens type automatically makes it a "better" lens
Kenny.
GeoffR
Reged: 31/05/2003
Loc: Bucks
Re: Push-pull or twist-zoom, is one better? [Re: mediaman]
      #804966 - 25/06/2009 22:24
Either type can "creep" it really is just a matter of personal preference for the user and convenience for the manufacturer. Though some physically long zooms could become almost impossible to use if they aren't of the "two touch" variety.
BenchistaModerator
Which Tyler
Reged: 11/08/2000
Re: Push-pull or twist-zoom, is one better? [Re: GeoffR]
      #804974 - 25/06/2009 22:36
Back in the late 70s, the trombone type were generally much preferred for their speed of use. In the AF era, the two touch type are dominant because of greater precision. I was playing with an old Nikkor 100-300mm f5.6 yesterday, a trombone type, and it's very nice.
Nick
www.nbrphoto.com
Going potty
Reged: 14/04/2003
Loc: Sussex-by-the-Sea
      #805153 - 26/06/2009 12:33
I have several zooms in both types and I think I'd just plump for the two touch type as better overall. Most of my one touch (push-pull) types are a bit stiff in operation and a bit tricky to zoom with precision while on the whole the two touch types are better in this respect - although as with most things the original cost, and thereby build quality, tend to have a bearing on ease and precision of use.
Perhaps the exception to this is my 70-210 f4 Series E Nikon which has a very nice and easy-to-use slide - although inevitably it can creep quite a lot if angle up or down too much and not held in place...
Completely BSRIPN
ElSid Gallery
Terrorist?............or potential photographer?.......
There are no people more opressed than those who willingly opress themselves
Malcolm_Stewart
Carpal \'Tunnel
Reged: 11/07/2005
Loc: Milton Keynes, UK
      #805159 - 26/06/2009 12:46
All zooms which change length must act as dust suckers to some degree - the only zoom I have which is fixed in length is my EF 70-200 f4L. Does it matter, probably not in the UK, but in countries where there's dust storms with fine sand, it's a serious issue. (Gets into the USM mechanisms as well if they're not adequately sealed.)
Malcolm Stewart
swanseadave
Reged: 05/10/2007
Loc: Swansea, Gateway to Gower
      #805165 - 26/06/2009 13:03
I have a Sigma 70-210 f4 one touch zoom,which is in Fuji x mount,now unusable since I have no functioning camera on which to mount it.While optically sound,it has always suffered from zoom creep.It must be a design fault.
Dave CRIPN
my flickr
Going potty
Reged: 14/04/2003
Re: Push-pull or twist-zoom, is one better? [Re: swanseadave]
      #806767 - 02/07/2009 09:16
The problem with zoom mechanisms is that they have to be a compromise design to some extent. Too tight and the lens is difficult to zoom smoothly and with precision, too loose and it creeps. As I said above my Series E Nikon zooms very smoothly but does creep quite easily while my much tighter Tamron 200-400 doesn't creep much if at all - but is very difficult to zoom precisely. It's all a matter of swings and roundabouts though, as with much else, I suspect that the more expensive and well constructed a lens is the closer to ideal the compromise becomes.
PS the Nikon E isn't the lens with the worst creep that I have - that honour must go to an aged 35-135 USM Canon which I have previously described as not suffering from zoom creep so much as zoom sprint... In this case I suspect it's a combination of poor design, mediocre build quality and sheer age - boy is it loose...
Completely BSRIPN
ElSid Gallery
parisian
Over the hill and far away...
Reged: 10/02/2002
Loc: Môn mam cymru
Re: Push-pull or twist-zoom, is one better? [Re: El Sid]
      #806781 - 02/07/2009 09:46
Quote:
boy is it loose...
I had an ex-wife like that!
JustMono
PeteRob
Reged: 30/03/2004
Re: Push-pull or twist-zoom, is one better? [Re: Benchista]
      #806959 - 02/07/2009 18:35
Yes you are right. I had not thought of it before but in manual focus days the 2-touch zoom was deprecated. I had a 80-200 f2.8 that I bought s/h mint for next to nothing because it was 2-touch (ok it was a konica mount) so I never used a one-touch and was happy to be different. Now with AF the 2-touch is a de facto 1-touch. Thank you for the insight!
Carpal \'Tunnel
Reged: 05/02/2007
Loc: Edinburgh
Re: Push-pull or twist-zoom, is one better? [Re: PeteRob]
      #806975 - 02/07/2009 19:02
I have a one-touch 70-200. It works fine when at either extreme (either 70 or 200) but inbetween fine focus is difficult without accidently changing the focal length. I much prefer a two-touch if it has to be a zoom.
Zou's Flickr Page
attack_donut
enthusiast
Reged: 16/12/2006
Loc: East Coast
Re: Push-pull or twist-zoom, is one better? [Re: Zou]
      #807214 - 03/07/2009 14:18
Can you kindly explain what the term "one touch" and "two touch" mean? Thanks
Wheelman
Reged: 23/11/2002
Loc: Kent/Sussex border
      #807218 - 03/07/2009 14:42
Term used on manual focus zooms that have sort of carried over......
One touch is a push-pull zoom as you hold it in one position and twist to focus and push/pull to zoom
Two touch is where there are two rings, one twists to focus the other twists to zoom
nowadays with auto focus they are both theoretically one touch as you either twist or push/pull to zoom and the camera sorts out focussing. (unless you turn AF off of course )
Hope this helps
Colin
IRIPN
When you don't know where you are going then any road will do
Still_Togging_Along
Reged: 24/09/2008
Loc: Reading, Berkshire UK
Re: Push-pull or twist-zoom, is one better? [Re: Wheelman]
      #811210 - 18/07/2009 09:35
I would guess that both 'systems' have their plus and minus points;
The Push-pull versions offer focus-override (when it's an AF version) and zoom adjustment via a single control and some of these also have a DOF markers on the barrel assembly. However, I would guess that over a period of time these optics become 'dust-suckers' due to wear and tear upon the seals used.
The versions with 2 twist rings, may well be 'ergonomically' less satisfactory to some people, because it uses two rings and users could well end up accidentally rotating the 'wrong' ring. However, they may well be less prone to dust-sucking because the mechanism moves around inside the main barrel.
The internal design of the 2 ring zooms, are likely to be more complex, but I would guess only a lens designer would be able to tell you which of the 2 systems, imposes the least compromises due to the accuracy required in positioning the various elements where they need to be.
40+ years of togging, but still learning!
beejaybee
Marvin
Reged: 18/07/2007
Loc: Really Here In Name Only
Re: Push-pull or twist-zoom, is one better? [Re: Still_Togging_Along]
      #811228 - 18/07/2009 10:59
This is a question of how much the volume changes when the zoom is operated, not the mechanism for working it. Many two ring action zooms suck in or blow out a considerable volume of air when the zoom is operated, and some push/pull & twist action zooms don't.
The basic issue is that push/pull & twist action doesn't work with AF motors unless a "continuous MF" clutch mechanism is used, and using the same ring for zoom & focus with a USM type AF drive is asking to get the focus wrong when users don't realise that they're inadvertently over-riding the AF focus mechanism when zooming whilst half pressing the shutter release. Push/pull & twist makes lots of sense when focusing manually, to the extent that two ring action zooms looked like becoming an endangered species until AF became dominant.
PHOTOSHOP ELEMENTS 8
0 registered and 3 anonymous users are browsing this forum.
Moderator:  Mat Gallagher, lisadb, mark_jacobs, Siuya, Benchista, Nigel Atherton, TheFatControlleR, Fen, Damien Demolder, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.068 seconds in which 0.007 seconds were spent on a total of 12 queries. Zlib compression disabled.
