Equipment >> Lens Matters
Jump to first unread post. Pages: 1 | 2 | >> (show all)
hech54
Reged: 20/05/2006
Loc: Germany and U.S.A.
I Take It This Is HAZE?
      #801496 - 16/06/2009 08:31
Top right-hand portion of the pics....the trees look "hazy" to me. Any thoughts? It's my beloved Nikon 70-210D...old, inexpensive, but still a great lens in good light.
Does the picture turn out differently than what you see in the viewfinder?
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
Re: I Take It This Is HAZE? [Re: hech54]
      #801532 - 16/06/2009 10:04
Looks like flare to me, I take it the picture was taken around mid day and slightly against the light. If you were not using a lens hood, using one may help.
Regards,
ZX9 (Keith Hudson)
hech54
Reged: 20/05/2006
Re: I Take It This Is HAZE? [Re: zx9]
      #801541 - 16/06/2009 10:21
The sun was on my left. I was definitely pointing more away from the sun than towards it.
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
      #801666 - 16/06/2009 15:42
I can see that the light is from your left, but did you use a lens hood? Or are you using a low cost UV / sky light filter because these can cause problems in bright light too.
Regards,
ZX9 (Keith Hudson)
hech54
Reged: 20/05/2006
      #801683 - 16/06/2009 16:52
I'm not certain there is a lens hood for this lens....and I don't use any kind of filters or protection on my lenses....I just put my lens cap back on when not in use.
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
      #801751 - 16/06/2009 20:06
Nikon NH 24 screw in metal lens hood ?
Regards,
ZX9 (Keith Hudson)
parisian
Over the hill and far away...
Reged: 10/02/2002
Loc: Môn mam cymru
      #801952 - 17/06/2009 09:14
Lens flare - end of.
Older lenses NEED a hood in any light. Better protection than filters by the way!
JustMono
BigWill
Gorgeous oversensitive Nikon-loving cream puff
Reged: 08/09/2000
Loc: Northern Ireland
Re: I Take It This Is HAZE? [Re: parisian]
      #801957 - 17/06/2009 09:26
I'm not convinced it is lens flare Peter though it could be of course. I'd be inclined to go more for a dirty mark on the lens element somewhere (thumbprint?) either on the front or rear element? Has the OP checked the lens to see if there are any obvious marks on it? Just my 10p's worth.
BigWill
I'm sailing like a driftwood on a windy bay.
parisian
Reged: 10/02/2002
Loc: Môn mam cymru
Re: I Take It This Is HAZE? [Re: BigWill]
      #801961 - 17/06/2009 09:36
You could well be right Will, it is difficult to see with that background. It does look circular - to me at least - which led me to suspect flare. Worth a check on front and back elements all the same.
JustMono
daft_bikerModerator
Action Man!
Reged: 11/10/2006
Loc: Oot n aboot
      #802094 - 17/06/2009 15:04
I can only see thumbnails on my phone as the pics are links to a web page but was there someone nearby smoking? Is this quick burst of shots the only ones effected?
Not that I know what getting smoke in shots looks like
Andrew (BSRIPN) ... My pics on Flickr.
We do not inherit the earth from our ancestors, we borrow it from our children.
hech54
Reged: 20/05/2006
Re: I Take It This Is HAZE? [Re: daft_biker]
      #802150 - 17/06/2009 18:14
I'm open to the lens flare idea....but I'm also not convinced of it either. I don't think there is any way sunlight could have hit the front of the lens. The sun was on my left and a bit behind me and I was aiming right.
I've never had a flare problem with this lens....or any of my lenses as a matter of fact.
I thoroughly checked the front and back elements....no marks on them. I also attempted to look inside but wasn't sure from which direction was best to check from.
I'm going to go through my pics again.
GeoffR
Reged: 31/05/2003
Loc: Bucks
      #802175 - 17/06/2009 20:07
Looking at the larger images I would say that the problem is caused by the sun reflecting off the leaves and into the lens. This has produced a myriad of tiny points of flare, hence the undefined shape of the area. The cure in this case is a polarising filter.
hech54
Reged: 20/05/2006
Re: I Take It This Is HAZE? [Re: GeoffR]
      #802188 - 17/06/2009 20:47
That was my most recent thought actually. After looking at the other pics from that day....but taken with my 85mm f2....it seems the same trees also look a bit strange.
GeoffR
Reged: 31/05/2003
Loc: Bucks
      #802192 - 17/06/2009 20:59
Which confirms that it isn't the lens.
Nice shot by the way.
parisian
Reged: 10/02/2002
Loc: Môn mam cymru
      #802249 - 18/06/2009 06:35
Perhaps get a little closer?
JustMono
BigWill
Reged: 08/09/2000
      #802330 - 18/06/2009 10:40
Are you using film or digital? There's a possibility that it could be a mark on the sensor if it's digital? If it's film and these are prints we're looking at then perhaps it's a processing fault? If these are scanned prints from a flatbed scanner then there's a possibility it's a mark on your film scanner...................the list of possibilities is almost endless so I'd suggest that you take a few more piccies with the same camera and lens combination under different circumstances to see if the fault is persisting or not and thus eliminate a few possibilities?
BigWill
hech54
Reged: 20/05/2006
      #802354 - 18/06/2009 11:45
My only chance to get closer to one of the jumps was to battle with the sun. I broke out my 85mm f2 and took some shots in that direction.
Edited by hech54 (18/06/2009 11:49)
hech54
Reged: 20/05/2006
      #802355 - 18/06/2009 11:48
Quote:
Are you using film or digital? ?
D70...."Imagine The Limitations"
J/K....I still love my D70....but I have my
eye on a D90.
GeoffR
Reged: 31/05/2003
Loc: Bucks
      #802472 - 18/06/2009 17:29
That second picture suggests that there is no dirt on the sensor so I stick by my first impressions flare from the leaves.
GeoffR
Reged: 31/05/2003
Loc: Bucks
      #802473 - 18/06/2009 17:30
Too close, you have chopped the top of her head off!
PHOTOSHOP ELEMENTS 8
Moderator:  Mat Gallagher, lisadb, mark_jacobs, Siuya, Benchista, Nigel Atherton, TheFatControlleR, Fen, Damien Demolder, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.063 seconds in which 0.005 seconds were spent on a total of 13 queries. Zlib compression disabled.
