What Digital Camera (CLOSED) >> WDC Help
SafariGirl5
Reged: 31/05/2009
Which lens for the Serengeti??
      #796839 - 31/05/2009 17:21
Hi All
I need advice please! I am about to purchase a D90 but cannot decide on which zoom lens to buy. I want a fast, good focal length which will help me to capture good action shots of the wildebeest migration crossing on the mara. I just can't make my mind up, so any advice would be greatly appreciated. My pocket isn't huge so something costing £2K is out (unfortunately!). This will be my third trip and I want to improve on earlier photos taken with a s9600. So am seriously upgrading.
Many thanks everyone
deddard
Reged: 11/03/2008
Re: Which lens for the Serengeti?? [Re: SafariGirl5]
      #796924 - 31/05/2009 23:00
I can't give specifics - there are loads of options depending on what you are willing to carry (such as the sigma 50-500 or 150-500 IS)
The one thing that is to your advantage is that in the Serengeti you won't need a superfast lens, as the D90 has the same sensor as the D300 which is good in low light or at higher ISOs.
Secondly there will be plenty of light there - combine this with the ISO capabilities and your choices are a bit wider than they otherwise would be.
I think you should seriously consider the dust proofing on some of the lenses. I have the Sigma 150-500, and I think it's probably a better bet than some others (par for the course - the more the lens costs, the better built it usually is) but check with some of the others on here, as I ain't been to Africa!
Another possibility would be something upto 400mm as long as it's aperture is fairly low (5.6 max) as you could then take a teleconverter as well.
nspur
Reged: 20/07/2005
Loc: Derbyshire
Re: Which lens for the Serengeti?? [Re: deddard]
      #797177 - 01/06/2009 20:23
I would recommend the Sigma 70-200 EX HSM f2.8 plus a teleconverter, probably the 1.4 times. That will give you a field of view equal to 420mm on film/full-frame. If you need more effective range you can always crop your image but the migration is sufficiently panoramic that 200mm plus a TC could be the best option.
Personally I would take my Nikkor 80-200m f4, a manual focus lens, plus a 2 times teleconverter but I don't think that would meter on the D90 (it does on my FujiFilm S5).
Nick
Straightarm
Reged: 02/05/2001
Loc: Exiled in the Beautiful South
Re: Which lens for the Serengeti?? [Re: nspur]
      #797283 - 02/06/2009 01:52
I think that's too short
I would suggest that even with a cropped camera 400mm is needed.
Have you thought about hiring a lens rather than buying outright?
Simon
Mat GallagherModerator
WDC Deputy Editor
Reged: 02/04/2009
Loc: London
Re: Which lens for the Serengeti?? [Re: Straightarm]
      #797422 - 02/06/2009 16:39
Unfortunately you really do get what you pay for with long lenses and there's no real substitute for serious glass. However, there are a few options with Sigma being your best bet on the whole. Their 150-500mm f/5-6.3 is definitely one to consider, as is the slightly cheaper 120-400mm f/4.5-5.6. Alternatively if you want something fast either the Sigma or Tamron 70-200mm f/2.8 lenses are a good option and by adding a 2x converter you will still get an f/5.6 aperture and an equivalent of 600mm, though no image stabilisation.
PHOTOSHOP ELEMENTS 8
Moderator:  Mat Gallagher, lisadb, mark_jacobs, Siuya, Benchista, Damien Demolder, AndrewC, TheFatControlleR, Fen, Nigel Atherton, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.058 seconds in which 0.004 seconds were spent on a total of 12 queries. Zlib compression disabled.
