attack_donut
enthusiast
Reged: 16/12/2006
Loc: East Coast
I've got the lenses from my N4004, and getting digital colour means simply buying a body, however, I do want to make sure all my lenses work with a new digital Nikon, I've heard some don't like older lenses.
Here's what I have:
Nikon AF Nikkor 35-70mm f/2.8 (all steel construction one, very heavy. Older lens I'm guessing.)
Tamron SP AF Aspherical Di LD (IF) 17-35mm f/2.8-4
Nikon AF Nikkor 75-240mm f/4.5-5.6 D (plastic construction, has serial number 2139xx)
Assuming that the d-40-d80s would all like these lenses equally, is it just a matter of getting the latest one, or is it a case of newest isn't neccessarily best?
Cheers! AD
P.S. Set a budget of $500.00 US, which is why the D90s are out, can't get one for that range.
-------------------- So rise up, o ye lost ones
As one we will claw the clouds
Rise up, the forsaken and dethroned
A legion wronged, to claw the clouds
Barney
Baht 'at
Reged: 16/12/2005
Loc: Harrogate, North Yorks
The D40/D40x/D60 bodies won't auto focus on non AF-S lenses. The D50/D70/70S/D80/D100/D200 will.
-------------------- "Wrong on so many different levels."
Flickr
attack_donut
enthusiast
Reged: 16/12/2006
Loc: East Coast
How do I determine if the lens is an AF-S?
Barney
Baht 'at
Reged: 16/12/2005
It should say on it. Other than that check out the Nikon website and google. If the lens is described as AF or AF-D then it isn't AF-S (i.e. it doesn't have a built in focus motor).
By the way, 3rd party manufacturers label their lenses differently, e.g. Sigma call their AF-S designation HSM.
Flickr
GeoffR
Reged: 31/05/2003
Loc: Bucks
The 35-70 f2.8 is NOT AF-S because it was replaced by the 28-70 f2.8 AF-S. The Tamron is almost certainly not AF-S because I don;t think the have an equivalent. The Nikon 75-240 is the only on I think you need to check as I have no knowledge of this lens.
Learning
Ethelred the Ill-Named
Reged: 26/09/2006
Loc: Nottingham
If the lens AF is driven by a screwdriver shaped spigot and socket then you need a D50 or D80 from the lower end cameras. If you can afford a D200 or D300 so much the better. If you want to stay with full frame then be assured that the D700, D3 and D3x will also AF with the older AF and AF-D lenses. The only exceptions are a tiny number of very odd lens designed for a very rare AF version of the F3. You can't use them but I understand that if you find one at junk prices they are worth buying as a collectors item. Just buy the D80.
Towershot
Reged: 19/03/2007
Loc: Lancashire, U,K.
D80, good camrera and you can use a lot of old lenses on it.
-------------------- Got a good camera, now to get a good photographer.:~<
Rick
IvorETower
Little Buttercup
Reged: 15/11/2006
Loc: Camberley, Surrey
All the lenses should work on the D40 as well as the D80, but they won't auto-focus on it. In your situation, I'd go for the D80 0ver the D40 anyway
-------------------- Too many cameras, too many lenses.......
attack_donut
enthusiast
Reged: 16/12/2006
Loc: East Coast
Thanks for the heads up and advice. Will let you know what I find at a good value.
Cheers!
phiggy
Reged: 15/01/2002
Loc: Shropshire U.K.
My choice would be the D80 I have 2 sitting in there boxes at home that I used for a short while before buying a D3 and a pair of S5ro bodies. Most of my accepted work in national and international exhibitions were taken with the D80. I certainly would go for one over the over priced s/h D200s I doubt you will be disappointed. I know I'm not and they will work fine with the lenses you have. The Nikon AF 35-70mm f2.8 lens you have is a corker and sort after by FX owners
-------------------- Phiggy
Take nothing but photos leave nothing but Footprints
