Equipment >> Canon Conflab
 |  Print Topic Pages: 1
alanS
The Flameproof Dr Dust
Reged: 30/09/2005
Loc: Up North, England.
Can anyone help with a Canonet QL17?
      #794167 - 20/05/2009 19:17
I've recently bought a Canonet QL17 and I'm trying to find out what some of the controls do as I haven't got a manual and the manuals I've found on the internet seem to be for a slightly different GIII model.
Anyway, the controls I'm struggling over are all on the lens and I wonder if anyone can help me with them?
1. There's a small fingernail operated control marked with an M at one end and an X at the other.
2. Just near the M-X control there's a small hooked "button" which can be pressed.
3. On the underside of the lens there's a thumbnail operated slider which may be the self timer. It only moves a small amount, not the full length of the slot and seems to give a delay of about 2 seconds.
alanS
Reged: 30/09/2005
Re: Can anyone help with a Canonet QL17? [Re: alanS]
      #794169 - 20/05/2009 19:29
I've worked out what 2 does, if I press it I can select longer exposures and B.
Just 1 and 3 to figure out now.
Roger_Provins
Made-it Man
Reged: 22/10/2005
Loc: Gloucester, UK
      #794170 - 20/05/2009 19:33
M and X are flash settings - X is electronic flash and M bulb.
Have you looked at this web page ... there are also links at the bottom of the page.
Rog
alanS
Reged: 30/09/2005
Re: Can anyone help with a Canonet QL17? [Re: Roger_Provins]
      #794172 - 20/05/2009 19:37
Great stuff.
Just the self timer to work out now. It only moves a little way along the slot, I don't know if it's a fault of if 2 seconds is all you get.
Malcolm_Stewart
Carpal \'Tunnel
Reged: 11/07/2005
Loc: Milton Keynes, UK
      #794184 - 20/05/2009 19:47
I think this model ran for quite a time, and that there were several similar models carrying the f1.7 lens.
That's the flash sync selector: M for flash bulbs, X for electronic flash. It seems not to exist on mine, so I guess mine is a later version which has a flash shoe, with shoe + two contacts.
On mine, that's the lock-release for the aperture control.
The 10s delay on mine is just below the clear viewfinder window.
If you PM me your email address I can email you various relevant things I've downloaded from the web - URLs long forgotten.
I assume you've found how to change film speed, and the flash guide number setting?
Mine has a Copal shutter, and serial number is D27xxx.
HTH
Malcolm Stewart
alanS
Reged: 30/09/2005
Re: Can anyone help with a Canonet QL17? [Re: Malcolm_Stewart]
      #794189 - 20/05/2009 19:54
Hi,
Mine's a CORPAL-SV.
I'm ok with the film speed, that's set with a thumbnail control on the underside of the lens.
The last mystery control is on the underside of the lens and just above the CORPAL-SV lettering. It's a slot maybe an inch or so long with a thumbnail control at one end but it hardly moves and wont go anywhere near the full length of the slot.
I think it's a time delay and it does give a delay of about 2 seconds but I can't see anything obstructing it. If it is the time delay and it is faulty I might just out up with it.
Thanks for the offer...PM on it's way...
Malcolm_Stewart
Carpal \'Tunnel
Reged: 11/07/2005
      #794195 - 20/05/2009 20:06
On mine the delay seems not to work unless I take the Aperture off its Auto ( A ) setting, and then I can get ~10s delay. I think the camera uses a trapped needle form of exposure automation so perhaps the delay mechanism isn't strong enough to do both a delay and trap the needle?
Malcolm Stewart
alanS
Reged: 30/09/2005
      #794199 - 20/05/2009 20:15
It works on auto and when moved off and onto the various aperture settings too but it always gives the same delay of about 2 seconds.
I think that the lever not moving very far is a clue, I think it's probably faulty.
I'll have to decide if this matters on not and contact the ebay seller if I decide that it does matter.
What a shame.
Malcolm_Stewart
Carpal \'Tunnel
Reged: 11/07/2005
      #794204 - 20/05/2009 20:24
Your email is on its way to you with about 1.8Mb of files and folders. Just in case the relative addressing gets screwed up, I saved them originally under:-
G:\Downloads\Canon\Canonet GIII
Malcolm Stewart
alanS
Reged: 30/09/2005
      #794206 - 20/05/2009 20:28
Yes, got it thanks.
RogerMac
Hotshoe Shuffler
Reged: 25/03/2007
Loc: Reading
      #794967 - 24/05/2009 06:56
If you PM me with a snail mail address I will photocopy the manual and send it to you. I can not do it until the end of the week as I am away from home for a few days
Roger
alanS
Reged: 30/09/2005
Re: Can anyone help with a Canonet QL17? [Re: RogerMac]
      #795056 - 24/05/2009 16:48
Thanks...Very kind offer
PHOTOSHOP ELEMENTS 8
1 registered and 4 anonymous users are browsing this forum.
Moderator:  admin, lisadb, Mat Gallagher, Benchista, Siuya, Fen, TheFatControlleR, Damien Demolder, AndrewC, mark_jacobs, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.058 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression disabled.
